trouble finding a map/07 SG/PCV
Old Nov 4, 2014 | 05:16 AM
bufbills's Avatar
bufbills
Default trouble finding a map/07 SG/PCV
Hello. I did a set of 255s this weekend. Cant locate a map for 2 into 1 for an 07.
Stock 96
255s
SE breather
2 into 1
I have a request in at vtwin but was wondering if anyone here has a similar set up and wouldnt mind sharing. All I can find is for true duals or slipons. Id like to get close before I go in for a tune next week.
Thanks
Old Nov 4, 2014 | 05:50 AM
mpr3369's Avatar
mpr3369
Try the power commander website. They have a list of maps for all different setups.
Old Nov 4, 2014 | 05:59 AM
bufbills's Avatar
bufbills
i did. all i could find was true duals and slipons.
Old Nov 4, 2014 | 06:01 AM
Notgrownup's Avatar
Notgrownup
That will be close enough, it will be better than nothing, it just richens it a bit...
Old Nov 4, 2014 | 06:07 AM
bufbills's Avatar
bufbills
coin flip? Im thinking slipons over trues.
Old Nov 4, 2014 | 07:59 AM
WILDWOOD_1124's Avatar
WILDWOOD_1124
Slip on's are more like a 2 into 1 than true dual's .
Old Nov 4, 2014 | 08:29 AM
UltraNutZ's Avatar
UltraNutZ
what 2-1 exhaust?
Old Nov 4, 2014 | 08:32 AM
bufbills's Avatar
bufbills
Originally Posted by UltraNutZ
what 2-1 exhaust?
propipe
Old Nov 4, 2014 | 08:40 AM
UltraNutZ's Avatar
UltraNutZ
this will get you close to where you need to be. Your tuner will dial it in for you but this will let you ride without issue until then.
The file has the .zip extension for uploading purposes. Once you get it on your computer, rename the extension to .pvm
File Type: zip
Old Nov 4, 2014 | 08:46 AM
bufbills's Avatar
bufbills
Thank you sir!
