13 FLHTK Chubby Bagger Bars install
Old Nov 13, 2014 | 06:10 PM
05UltraBob's Avatar
05UltraBob
Default 13 FLHTK Chubby Bagger Bars install
Finally got the last piece to the puzzle, the bars arrived today!!
So.... I have
10" Wild1s black Chubby Bagger Bars
CVO Twist Grip Sensor
+4 Magnum black braided clutch cable
+4 Drag Specialties brake line. May not need, but wanted to have on hand.
Urethane riser bushings
Black clutch and brake levers.
And the correct Molex connector tool.
Now if the temps would get above freezing, so I don't break any brittle plastic pieces, I could get them swapped.
I am excited to get started!!!
Old Nov 13, 2014 | 06:21 PM
Ragtop's Avatar
Ragtop
Have fun and take your time. Make sure to cover your tank and front fender in case something drops!
Post up some pics when you're done.
Old Nov 13, 2014 | 06:26 PM
05UltraBob's Avatar
05UltraBob
Gonna probably remove the tank, and yeah that, cover everything well.
This will be my third set of Chubbys I have installed. Did 2 sets on 2 different Ultras for the Ex. Now it's my turn!!!
Old Nov 21, 2014 | 06:51 PM
05UltraBob's Avatar
05UltraBob
Well..... I am into my bar swap. Had to buy new heated grips today. The throttle grip was sticking, it must have been deformed from the heat. $290.00 later and all is well. Hopefully bars will be installed on bike tomorrow. Then clutch cable swap. I am waiting on iPod interface, decided might as well do that while the outer fairing was removed.
A $450.00 job has now turned into over $1,000 job. LOL
Old Nov 21, 2014 | 06:58 PM
user 8373900's Avatar
user 8373900
So.... I have
Don't forget to wedge the brake lever open. Those little switches are a biotch! ;-)
Mark
Old Nov 21, 2014 | 06:59 PM
05UltraBob's Avatar
05UltraBob
No problem on the brake switch.
woodthumb2
Apr 2, 2018 04:17 PM
strippedthread1
Oct 18, 2015 07:11 AM
rs03371
Jul 8, 2013 10:08 AM
akroguy
May 30, 2010 06:00 AM
