Accessory connector
Old Nov 14, 2014 | 04:21 PM
dspencer's Avatar
dspencer
Default Accessory connector
I know this has been covered somewhere but I have a 03 Rk Classic and have seen the connector under the seat many times. I know it is controlled by the left switch on the nacelle.
Was thinking of wanting to have something run there so I can run my iPhone and keep it charging. It is the 4 pin kind. I assume I need some adaptor so I can use USB. Any insight appreciated. Thanks
Ps-for it to be powered up, switch must be on?
Old Nov 14, 2014 | 05:01 PM
dawg's Avatar
dawg
http://www.3brpowersports.com/products.php. Scroll down to the bottom of the page.
Old Nov 14, 2014 | 05:32 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
the 4 holes in the aux are all powered,one is ignition switch one is brake light switch one is aux switch one hot. u can use a crimp on duetsch? connector looks like a small banana plug about 10 cents or harley makes a harness about 20$.
Old Nov 14, 2014 | 06:07 PM
SeaZund's Avatar
SeaZund
I think you can get the aux cable with a cigarette lighter style connector from Harley for about 20 bucks...then plug in a cheepo $5 cigarette lighter/USB charger and you're all set
Old Nov 14, 2014 | 06:11 PM
SeaZund's Avatar
SeaZund
or if you've already got a battery tender pigtail on your bike; get the cig lighter at an auto parts store and build your own cable (plus the cheepo USB charger)
Old Nov 14, 2014 | 06:15 PM
Delta's Avatar
Delta
Here's what each wire does.
Old Nov 14, 2014 | 11:23 PM
From_Behind's Avatar
From_Behind
Or, go an even easier route with this!!!!
Old Nov 15, 2014 | 07:01 AM
Hammerhead Pat's Avatar
Hammerhead Pat
Does your bike have the 2 wires coming off the back of the headlight?? Orange/white and a black wire. If so, you can wire a 12v receptacle( cigarette type) and use that to power/charge your stuff. If the headlight is on, you have power to the plug, headlight off, no juice.....
Old Nov 15, 2014 | 08:00 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Or, you could add a bunch of stuff...
Amazon.com: NOCO ISCC2 5-Way SAE Adapter Connector: Automotive Amazon.com: NOCO ISCC2 5-Way SAE Adapter Connector: Automotive
Old Nov 15, 2014 | 12:56 PM
dspencer's Avatar
dspencer
Thanks for the great ideas. Just need to decide what route to go.
