2005 Ultra classic needing help
I will be installing this SE cam plate 25284-11 and also thinking of swapping my stock cam to andrews TW21 cam. Is this the correct cam for me?
Coz I have read that andrews 21 comes in many versions such as 21N, 21HG and so on.
I will be installing these by myself and I may need all the helps I can get here including all the part numbers needed for this project to be done.
Thank you so much in advance.
Sony
I just pulled the trigger to buy 25284-11... As for the cam, i really think TW21 is the one for me. However, I may need a map for my race tuner.
Any help is greatly appreciated..
Welcome to the Forums.
A lack of replies, doesn't mean an unwillingness to help- but Members not having the expertise or knowledge to help with your particular question.
Given the general nature of the title heading..."needing help"- around here that can mean routine things such as "where can I buy a colour matched 28 piece Live to Ride picnic set" or "how do i check the oil".
I'm not smart enough to know if your question and the answer given was sufficient- I hope so.
There are plenty of threads on the tw21 and other cams- selection really depends on the weight and gearing and where in the rpm band you need to see the greatest usable gains. ( all motorway or all twisties)
Other considerations are whether the cams are "bolt in" or will head work, clearancing or springs need changing...lifters too.
And whether "Down Below" has Emissions Testing or Regulations which might affect your choice.
Lots of threads, read up on some- look at dyno charts...
Keep coming back.
Mike
With that said. I absolutely love the Andrews 21 cams on an 88" twin cam.
Tons of low end pull, heck it pulls all the time. I also have the SE mufflers. Great combination with the stock headers. I think you will be very happy.
Thanks for the reply. Yeah.. Maybe I give this thread a wrong title. Thanks for the bump
