Battery problem?
Old Nov 28, 2014 | 06:05 PM
Flhrhog's Avatar
Flhrhog
Default Battery problem?
I have a 2012 road king. I have done a few upgrades on it. Jackpot slipons, pvc5, decatted head pipe. It has always cranked kind of slow. Meaning it would turn over a few times before it would crank. The only other bike I have is an 87 evo that when u hit the starter it will whine if it is on compression and then bang it is running. I keep the rk on a trickle charger all the time when not riding. It was about 45 when I started it up this morning. It grunted pretty hard but fired up. Went to a buddies house and when I cranked her up it just about didn't wind over fast enough to fire up? Two year old battery, checked the connections, all good. I think it would have cranked right up after staying on a trickle charger? Any thing else I need to check besides the battery?
Old Nov 28, 2014 | 06:18 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Yes, dump the trickle charger and purchase a battery tender. A battery that's continuously connected to a trickle charger will not last very long due to the constant state of continuous charging whereas a tender will run up to full charge then shut itself off and monitor the battery from there.
Old Nov 28, 2014 | 06:19 PM
dforeid's Avatar
dforeid
Curious if you don't have a dead or low cell in the battery.
Old Nov 28, 2014 | 06:22 PM
RollaMo's Avatar
RollaMo
Have the battery load tested. That will tell you if the battery is any good or not.
Also, make sure all connections are good and tight.
A 2 year old battery should not have any problems turning the bike over.
If it doesn't want to "wind over" (your words) fast enough to fire, then something isn't right.
Old Nov 28, 2014 | 06:59 PM
mkguitar's Avatar
mkguitar
...it will whine if it is on compression...
the whining you hear is the windings on the starter motor burning up= bad.
flick the starter button...then press the starter button to crank and start.
on late models, they are programmed to spin a couple of times before they light up.
as above- load test your battery...charge it with a charger, then pull it and test at autozone.
while it is out check the other end of the cable connections for clean and secure
this would show immediately...each cell carries about 2.2 volts ( x6) so a dead cell in a 12 volt battery = a 10 volt battery- you'd see that on the meter right away.
mike
Old Nov 28, 2014 | 07:37 PM
Flhrhog's Avatar
Flhrhog
If it doesn't want to "wind over" (your words) fast enough to fire, then something isn't right.[/QUOTE]
Is there a problem with my words? I have already checked the connections. Will get my multi meter out and check the voltage tomorrow. I called it a trickle charger but it is a battery tender. Bought from amazon after I got the new bike. My friend has a 2010 ultra and his battery is still going strong and he doesn't even keep it on a charger. I will do some checking tomorrow. Thanks.
Old Nov 28, 2014 | 08:48 PM
themensh's Avatar
themensh
"Meaning it would turn over a few times before it would crank."...Hmmmm...Ok. My bike (2013 FLT will turn over three-four times before it starts. Programmed that way I think. Yours turns over before it cranks. Normal I think.
Old Nov 28, 2014 | 08:57 PM
btsom's Avatar
btsom
You can do a "shade tree" capacity check yourself if that multi meter is digital (it can react quickly with no meter inertia). Hook it up to your fully charged installed battery and do a start while you watch the meter. If the voltage drops below 9.6 your battery is weak, well below 9.6 and just buy a new one. Once the engine is running, watch for the voltage while the battery is charging. Above 2000 rpm you should see voltage in the vicinity of 13.5 to the low 14s. It might not be the battery but low charging voltage. Have you (or someone) added a bunch of electrical stuff resulting in heavy drain to the electrical system?
Old Nov 28, 2014 | 09:18 PM
EasTexUltra12's Avatar
EasTexUltra12
I just went through this exact same thing. New battery fixed me right up.
David
Old Nov 28, 2014 | 11:03 PM
garsam's Avatar
garsam
Maybe in the tune your running? Start up timing to advanced?
