primary cover
Old Dec 10, 2014 | 01:00 PM
jmn1960's Avatar
jmn1960
Default primary cover
need to pull primary cover to pull starter to rebuild the soleniod. do i have to remove the front floorboard ? or will it clear the compensator with out pulling the floorboard , mabe remove all allen bolts and just tilting the cover to the floor to get to the starter jack shaft.
Thanks mike
Old Dec 10, 2014 | 01:43 PM
grbrown's Avatar
grbrown
I've only ever removed the footboard. Remember there are large things inside the cover, the alternator and clutch, so the cover won't move very far if you can't disengage it from those. It is hardly difficult to take the footboard off!
Old Dec 10, 2014 | 01:57 PM
flhchaz's Avatar
flhchaz
I just did this on my dad's 02 Road King. The front floor board has to come off. I tried to just loosen it and move it, but realized it was just easier to take all 3 bolts out of and take it off. I think is a 3/8" allen in the front, 1/2" bolt that goes through the back side of the frame into the floorboard and 1/2" nut and bolt through the floor board at the jiffy stand bracket.
Old Dec 10, 2014 | 02:30 PM
williamfrog's Avatar
williamfrog
My 08 Street Glide it needs to be removed
Old Dec 10, 2014 | 06:12 PM
margin5's Avatar
margin5
Just replaced my inner primary with a chrome one. Take the footboard off. I also took the shifter, passenger footboard and kickstand off as the manual says. give yourself some room. make sure to replace the gasket. Wasn't bad at all.
Old Dec 10, 2014 | 06:15 PM
Gliden's Avatar
Gliden
Thanks mike
Isn't the starter and the solenoid outside on top by the trans ?
Old Dec 10, 2014 | 06:37 PM
jmn1960's Avatar
jmn1960
yes it is but on a 2005 and lower you have to remove the primary cover to take the jackshaft loose ,, the 2006 and up do not need to remove the primary
Old Dec 10, 2014 | 06:39 PM
Stiggy's Avatar
Stiggy
You are correct ( and yes you need to remove the floorboard too.)
Gliden's Avatar
Gliden
Omg...ok. Thanks for the info. I'm a bit of a blockhead...lol
Good luck with it.
jmn1960's Avatar
jmn1960
thanks ,, been ther before but did not know if i had to do all that again ,, thought i could just loosen the bolts and tilt it far enough to access the jack shaft ,, oh well not that bad of a job ,, allready been in there a few times.
trhanks mike
Wabbit
Sep 5, 2024 06:05 PM
Eric Reichelt
Feb 7, 2016 10:15 AM
dj22312
Jan 11, 2012 01:43 PM
heritage jim
Aug 30, 2010 06:48 AM
02glide
Nov 7, 2006 01:51 AM
