Removing cam gears
Old Dec 14, 2014 | 09:09 AM
Sandcrab's Avatar
Sandcrab
Default Interesting
Originally Posted by dforeid
You can also do it by leaving it on the lift. Just put the bike in 6th, and then hold down on the rear brake pedal with your right arm while you crack the cam and crank bolts loose. You can use the same method when you are torquing them back on.
What a wonderful idea since mine is currently on a lift. Thanks for the suggestion, I never even thought about using the brake. The cams will be removed today, I am confident now. My lifters showed signs of skidding vice rolling see picture, so I am anticipating my cam will be toast also. My tensioner is grooved also after only 48975 miles. I will take some pictures this afternoon of my cams, before the games on TV.
Attached Thumbnails Removing cam gears-dscn9090-1280x960-.jpg   Removing cam gears-dscn9101.jpg
Old Dec 14, 2014 | 09:14 AM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Change this around for a minute. Have you ever ran the bike real low on oil before within the 48000 miles? What kind of oil do you use? Have you used the same oil since break in? Just seems like an excessive amount of where on the lifters. I could be wrong But IMO seems excessive.
Old Dec 14, 2014 | 09:54 AM
Sandcrab's Avatar
Sandcrab
Default My maintenance
Never ran it low on oil, always changed oil before it's time, switched to HD Synthetic at 1000 mile change, then at 3750 miles, switched to Amsoil synthetic 20W-50, and then last summer switched to Mobil-1 synthetic (20W-50), because the lifters just made so much noise. I could not agree more with you and my only explanation is when a group of us rode to Philly to eat a cheesesteak, we rolled up I-95 in 95 degree weather, and then hit traffic and got stuck going 3', stop, go 3' and stop, for about an hour maybe more, and my engine started pinging. Mine was the only one of about 10-12 bikes pinging, but it definitely got hot. From that point on, I heard my lifters upon start up. They just kept getting progressively worse until I decided to see what was causing them to make so much noise. I was embarassed to start my motor they made so much noise. So other than that one time when it got hot, I treat her pretty good. But why only my bike when every bike in our group suffered no damage but me, if in fact that was when it happened.
Old Dec 14, 2014 | 10:15 AM
GriffinDenim13FLHX
Remember reading something about this before... found it.
https://www.hdforums.com/forum/touri...fter-wear.html
rainsong
EVO
23
May 3, 2017 01:50 PM
BungoBill
EVO
50
Nov 18, 2013 02:04 PM
terrapin88
EVO
Apr 22, 2013 05:52 PM
Proud Marine Dad
EVO
Mar 28, 2013 04:40 PM
Keener
Engine Mechanical Topics
Apr 22, 2009 09:07 PM
