Kuryakyn relocation kit??
Old Dec 17, 2014 | 10:49 AM
MSP Dan's Avatar
MSP Dan
Originally Posted by mps1168
I found a George Anderson kit for sale from a member and got it and love it. But I also have machinist friends that did some designs of their own to make adaptor brackets for theirs after seeing what its like to have more room on mine. As for being "Adjustable" 99% of those who move it back just want to make more room so adjusting it isn't an issue.
mps
That's the one I was thinking of. I thought it might be George something but was afraid that I might be confusing it with George's Garage. Anyways... like I said, I've known a couple of people with George's relocation kit and they loved it. If I were to relocate one today I would definitely go that way as opposed to the Kuryakyn kit that I have now.
SeaZund's Avatar
SeaZund
Originally Posted by ReidRik_Von
A few years back I got one of the Kury Tpak relocators and have been happy with it. I needed to make some mods...I detailed the mods here...
can't see your mods, the link requires having to register at another website
Old Dec 17, 2014 | 11:58 AM
ReidRik_Von's Avatar
ReidRik_Von
Sorry about that...I forgot that RPB does require an account to view their forums. Luckily they have and edit that allowed me to grab the post copy & image links:
This was a project I got done over the winter holiday and finally got around to posting. When touring I have my T Pak on the 09 version of the HD solo rack and I am using the stock air-ride seat and bars. With this setup the T Pak was not close enough support my back so I searched for something that could bring it closer to me and couldn't find anything. I spoke with George ANderson and his unit only takes the T Pak backwards, not forwards. I ended up getting a Kuryakyn Quick-Adjust-Tour-Pak-Relocator http://www.kuryakyn.com/Products/390...-Pak-Relocator on Ebay for significantly less than SRP. THis unit provides 1 inch forward and 3 inches backward adjust-ability. I knew that this wasn't going to be enough forward adjustment so I looked at the install sheet http://www.kuryakyn.com/documents/in...-22HD-0610.pdf and figured that with a few modifications, this would get the T Pak where I needed it.
THis is a shot looking down on the T Pak relocator mounted on the solo rack:
#1 are the kit's mounting holes for the 09 style rack. I ended up drilling 4 new holes that allowed the kit to sit farther forward on the solo rack; these are shown as #2.
#3 is where the kit's rectangular stop block is mounted so that the T Pak can't slide out of the rails. I took the black steel plate that was on the stock radio rack and fabricated an extension for the kit that would support the T Pak in the position I wanted it. #4 is where the stop block now mounts on the extension.
The holes below #5 are where the kit originally had its aluminum locking blocks mounted. I drilled a new set of holes that allowed these locking blocks to move to the very front of the rails so that when the cam-locks are engaged, they are biting on a large portion of the blocks.
THis is the extension that I fabricated out of the steel plate that was on top of the radio box:
This gets sandwiched between the top of the solo rack and bottom of the kit towards the front of the bike. I have a set of washers in the back mounting holes to keep everything level.
This is the bottom of the contraption:
From the side:
From the front with the T Pak mounted:
THe chrome thing is the stop block that I mentioned.
And mounted on the bike:
The aluminum inner rails extend out of the chrome chrome rails allowing the T Pak to get really forward.
Another shot showing how far forward the T Pak can go:
Bottom of the T Pak is touching the back of the seat in this photo however I don't ride with it that far forward. I think the inner rails extend out about 1.5 inches.
So this got the T Pak where I wanted it but what became immediately evident was that the shape of the bottom of the box was not supporting my lower back. THe box cants away from my lower back so I needed to get some support and ended up with a sissy bar pad from one of the smaller HD bikes. It is attached with that stick on velcro stuff:
This shot also gives a good look at the rails that are attached to the bottom of the T Pak.
This has me 98 percent of the way there. After I get some miles on this setup I may need to cant the bottom of the pad a bit more towards my back and will try this with a few pieces of the velro.
One side benefit to this setup is that no spacers or risers are needed as the kit is just over an inch high which allows my saddle bag lids enough clearance to open.
And another post in the same thread:
After riding with the T-Pak on the solo rack I quickly became annoyed with the armrests on the King style backrest when I was leaning the bike. One of my projects this winter was to replace the King backrest with the smaller Chopped backrest. This was quite a bit of work as a useful template to drill the holes for the Chopped pad doesn't exist. Here is what I went through to get this installed:
https://www.hdforums.com/forum/touri...-tour-pak.html
Here are some photos with the new pad installed:
I took the bike for a nice ride last weekend and I love the new backrest. Had I to purchase the T-Pak again, I would have had the King T-Pak lid drilled for the Chopped pad.
Jerm21
Sep 21, 2009 09:48 PM
2007fxdc
Dec 15, 2007 03:56 PM
bobros
Jul 27, 2007 08:40 PM
happycamper
Jan 14, 2007 04:29 PM
Flatland Flyer
Apr 5, 2005 01:56 AM
