Wheel swap?
Old Dec 21, 2014 | 07:28 AM
CarolinaThunder's Avatar
CarolinaThunder
Exclamation Wheel swap?
Just looking for some clearer answers.
I have a 2000 Electra glide classic. I'm looking at buying a set of 2006 street glide wheels, that come with the stock tires and rotors still on them, and i'm assuming the bearings as well.
From my understanding the front should bolt right up but the rear is going to be slightly more involved due to the axle size. I'm guessing from what I have read, for the rear i'll just have to switch to smaller wheel bearings.
Would someone mind telling me what was involved when they did the same type of swap because I am supposed to be picking these things up in the next little while and I have to get back on the road.
Old Dec 21, 2014 | 07:37 AM
ultra_classic's Avatar
ultra_classic
you could go to the HD web site, and look at wheel installation kits [bearings and spacers in a box ] just for research so you can figure out if you need different size bearings, and /or size spacers. OR purchase 2 install kits, then you will have the correct bearings and spacers needed
Old Dec 21, 2014 | 07:45 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Put 3/4" bearings in the rear wheel. I'd use a 3/4" crush tube as well. That should be it. Front is good to go.
Old Dec 22, 2014 | 07:19 AM
CarolinaThunder
Thanks guys the replies are much appreciated.
Now the only thing I need to decide before going on with this is do I want to keep my stock swing arm or upgrade to the beefier 02 and up revised version
Old Dec 22, 2014 | 09:22 PM
BulldogBiker's Avatar
BulldogBiker
Or use these parts:
Later model swing arm conversion
48487-02 Spacers Qty = 2
48489-02 Spacers Qty = 2
9208 Spherical bearing Qty = 2
47564-86B Rubber mount Qty = 2
McMaster-Carr #6381K536 bushing 3/4 to 5/8. Qty=4
Alternate source for Spherical bearing -
Aurora Bearing (Illinois USA) GE25ET-2RS
Need to cut bushings to spacer size and ream for 5/8 shaft
Need to use pre 02 belt guard if using original wide drive belt
Need to replace 3/4 " bearings and spacer to 1" for rear wheel.
Need to use 1" axle with spacers.
Need green Loctite for bushing to spacer lock. Basically you are using 02 - 07 OEM parts to convert for 5/8" shaft from pre 02 swingarm. Install as per SM.
Old Dec 23, 2014 | 07:59 AM
grbrown's Avatar
grbrown
I did that on my earlier bike, by using adapter bushings for the swingarm axle, using the original smaller diameter. They are available from True-Track, Motorcycle Metal and others. The later swingarm is deeper in cross-section than your bike, so you may also need a later caliper, which is similar to yours.
Old Dec 23, 2014 | 05:42 PM
BulldogBiker
You can use your caliper but it needs to be reamed for 1" axle. If the Swingarm you are looking at has the axle, adjusters, and spacers; all should match up. Only problem is if you use the wide belt you need to use the belt guard from the original swingarm.
Old Dec 24, 2014 | 04:57 AM
grbrown's Avatar
grbrown
Wink
I upgraded my 1990 bike, so had the earlier caliper and changed to the later wheel as well! I also went to a wider tyre and narrower belt, all in one hit, to get it in.
Old Dec 10, 2015 | 01:24 PM
Podhy01's Avatar
Podhy01
Stage II
Also interested to know if it will work!
Old Dec 10, 2015 | 02:30 PM
tfi racing's Avatar
tfi racing
I went all the way with my 2001,150 tire on 16x3.5 Airstrike wheel,2002 up swing arm and axle,adapter bushings from Howard,Brembo caliper and bracket,1 1/8 belt and pulley.2013 18" Airstrike on front with matching axle,new take-off lowers,cowbells,Brembo calipers and rotors.Funny how project creep steps in,I only really needed a pair of new tires,now considering an Enforcer front wheel or a custom 21" if the right deal comes along...
Road Star
Wheels/Tires
Jan 18, 2019 01:49 AM
04Fxdl87
Dec 30, 2018 07:42 AM
BuddyK
Wheels/Tires
Sep 6, 2014 10:26 AM
SmokinRK
Mar 23, 2012 08:36 AM
Filmy
Apr 16, 2009 02:26 PM
