Progressive front lowering help
Old Jan 3, 2015 | 06:13 PM
nickd23's Avatar
nickd23
Default Progressive front lowering help
finishing up installing my as bolt on neck and needing to swap out my lowering kit as it was setup with a 2" drop when I got it. I took everything apart and drained the fork oil as I want to make sure im running a heavier weight. when I pulled the lower pin I was shocked to see that on one side I had 3 small springs and on the other there was only 2...?
so for me to go to just 1" of drop im assuming I need to only run 2 small springs on the lower pin and then install the main spring or do I need to run a plastic spacer to get the desired ride height or am I good to go with just the 2 small spring and the one large main one? thanks
Old Jan 3, 2015 | 10:06 PM
nickd23's Avatar
nickd23
Nothing?
Old Jan 4, 2015 | 08:14 AM
LilWick's Avatar
LilWick
You can download the install instructions from progressive. Don't guys at it.
street06bob
Apr 12, 2012 05:10 PM
Dustmaker
Apr 8, 2010 06:57 PM
Jaws87
Apr 21, 2008 06:45 AM
garyw
Apr 14, 2008 09:46 AM
cajun883custom
Jul 6, 2007 12:05 PM
