Battery Removal ?
Old Jan 4, 2015 | 12:08 PM
PaulFLHTC's Avatar
PaulFLHTC
Default Battery Removal ?
Need to change the battery in my 2008 FLHTC. Problem is last person did not replace the lifting strap to help get it out. Can't get my big hands in to grab a hold of it an pull forward at the same time. Anyone else have this problem and how did you get the old one out? Secrets, Tips, Small rental hands?
Old Jan 4, 2015 | 12:18 PM
uscanuck's Avatar
uscanuck
Happened to me once but I just dug my fingers hard into the top sides and pulled it out.
Probably would be easier to just screw some wire to the battery posts to use as a handle to pull it out.
Old Jan 4, 2015 | 12:20 PM
mkguitar's Avatar
mkguitar
1.) remove negative cable
2.) remove positive cable
( doing it in this order guarantees no sparks...on install + first).
you can then use the 2 cable bolts to lift using 2 pieces of wire looped around the bolts- do not let these touch ( short out)...so one in each hand
careful- you don't wanna drop it on the tank, get a hand under it as soon as it clears.
clean out the battery holder- if you see signs of acid damage/spill, clean with baking soda to neutralize
my strap was thin and just wore through. I replaced with a heavier length of 2" ( guitar strap)
mike
Old Jan 4, 2015 | 12:51 PM
PaulFLHTC's Avatar
PaulFLHTC
Thanks guys.. old leather strap two holes bolt right to battery terminals, lift right out. This place is great...
Old Jan 4, 2015 | 05:42 PM
waltz4's Avatar
waltz4
Default Old battery removal
Most of us have had to change a battery or two. On a battery that is difficult to get a hold on I always grab a terminal with vise grips or channel lock pliers. Lift it up and get a hand under it as quickly as possible to steady it and prevent dropping it on the bike or floor. I cut a piece from an old inner tube to line the bottom of the battery tray. I then cut another piece as wide as the battery that will come up the sides and fold over the top from each end. This makes for a snug fit, covers the terminals from the top, and assist in removing the battery the next time it needs service. Good luck.
Old Jan 4, 2015 | 08:31 PM
rpking's Avatar
rpking
my battery lifting strap broke when I tried to lift my battery out
I locked a pair of vice grips on each battery terminal and lifted it out
Old Jan 4, 2015 | 09:59 PM
gusotto's Avatar
gusotto
Never had a lifting strap... ever (since new.)
I did add a strap to aid in the removal.
Not much room in there.
Old Jan 5, 2015 | 02:55 PM
JOW_103's Avatar
JOW_103
I had same issue trying to remove the battery on my 2013 Ultra. Removal strap was underneath battery. Zip tie around the head of the terminal screw and was able to lift it out.
Old Jan 5, 2015 | 03:00 PM
howitzer88's Avatar
howitzer88
My '06 didn't have a lifting strap, so after working the battery out (PITA), I just cut some 1" nylon web strap from an old backpack and now I have a sling to remove the battery.
Old Jan 5, 2015 | 03:58 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Ummmm .............. The battery better be really dead, or it would get interesting really quick. LOL
I just clamp onto the NEG terminal with a pair of vice grips.
