Fork Seal driver
Old Jan 9, 2015 | 08:52 AM
maryvillept's Avatar
maryvillept
Default Fork Seal driver
Anyone have anything they use other than pvc pipe shaved down? Tried that method and had a failure so doing it right this time. I need 41mm driver. Or if you have an extra laying around and you got a new bike with larger forks and wanna sell your old let me know.
Old Jan 9, 2015 | 09:03 AM
nevada72's Avatar
nevada72
Easy to get from Amazon
http://www.amazon.com/Motion-Pro-08-0489-Ringer-Driver/dp/B009M4COVI http://www.amazon.com/Motion-Pro-08-0489-Ringer-Driver/dp/B009M4COVI
Curious as to why the PVC pipe didn't work. Did you use it with a mallet or as a slide?
Old Jan 9, 2015 | 09:11 AM
Uncle Larry's Avatar
Uncle Larry
I've always had good luck with PVC pipe ... but ... here's an alternative ... stop by a muffler shop ( with your seal ) and have him cut you a length of tail pipe and then "swedge" one end to the desired diameter ... It works quite well ... Good Luck
Old Jan 9, 2015 | 11:28 AM
maryvillept
By the time i had it shaved down to where it would fit in the lower, it was flimsy and somewhat sharp on the end. Tried with mallet and as a slide but never looked to even to me and it leaked.
I was trying to avoid buying a new one bc it may be the only time i ever use it with the size changing in new touring bikes.
Old Jan 9, 2015 | 12:38 PM
03 Fatboy's Avatar
03 Fatboy
Use the old seals to drive the new seals in, turn the old seal upside down against the new seal and tap the seal in with the pvc pipe. Then remove the old seal.
Old Jan 14, 2015 | 11:18 AM
maryvillept
Anyone have an extra they want to sell before I buy one
tonyd2017
Exhaust System Topics
Jul 29, 2018 04:46 PM
just plain john
Jan 8, 2018 07:49 AM
DavidStiebel
Jul 19, 2013 09:10 AM
98glider
EVO
16
Jun 16, 2012 07:02 PM
drfalken
Feb 4, 2011 11:08 PM
