Repair fairing nut
Old Jan 18, 2015 | 10:16 PM
VA_Larry's Avatar
VA_Larry
Default Repair fairing nut
2015 Ultra Limited
Seems the nut on the inner fairing above the brake side has some cross threads. I don't know if it came that way from the dealer or happened when I put windshield bags on a few weeks back.
I discovered it as an issue when I was installing a new windshield this weekend and planning some modifications.
Anyone know how to replace this fitting so the outer fairing will fit snug?
Old Jan 18, 2015 | 10:37 PM
SpiderPig's Avatar
SpiderPig
Here is a thread that might be of help for you.
https://www.hdforums.com/forum/touri...iring-nut.html
Old Jan 18, 2015 | 10:39 PM
fxdxruss's Avatar
fxdxruss
HD makes a repair nut. It's brass with threads on the outside and threads into the hole where the original pressed in one fit.
Russ
Old Jan 18, 2015 | 10:40 PM
Trucky911's Avatar
Trucky911
Another fix....
Old Jan 19, 2015 | 10:50 AM
VA_Larry's Avatar
VA_Larry
Thanks for the information. I should have searched the entire forum before opening a new subject.
I'm going to purchase some of the screw in inserts today. Might only need one for this repair but good to have on hand for the future.
Before I try to get the old insert out I'm going to try and re-tap the threads. If that fails then I can do the screw in insert.
Now the trick is doing this without letting my wife know I may have broken something on the new bike!
Old Jan 19, 2015 | 09:52 PM
VA_Larry's Avatar
VA_Larry
I stopped by the local hardware store today and bought the replacement inserts. Then I asked my neighbor to bring over a tap to try and rethread the existing insert.
The tap worked perfectly and fixed the threads.
Now I have the knowledge gained here and some spare inserts for the future. Where I'm confident I will need them.
Old Jan 20, 2015 | 07:46 AM
Rooster37's Avatar
Rooster37
I had to reap three on my fairing on my 13. I think the person at HD wasn't really trying. I had no trouble tapping them, just be patient.
JRCinNH
Aug 5, 2014 02:59 PM
Teardrop
Aug 4, 2013 01:58 PM
Dobe66
May 2, 2013 11:49 AM
BcDog
Mar 17, 2010 07:53 PM
ezglider
Feb 14, 2007 01:27 PM
