GPS wiring question
Old Apr 17, 2007 | 08:02 PM
04kingcustom's Avatar
04kingcustom
Stage II
Default GPS wiring question
I'm trying to wire my Garmin Zumo to my 04 RK. Can I use any of the unused plugs in the headlight nacelle on my Road King Custom?
Thanks; Steve
Old Apr 17, 2007 | 08:53 PM
FLRYDR's Avatar
FLRYDR
Default RE: GPS wiring question
Steve,
I just got finished installing a Garmin Quest 2 (same as HD Conquest) on my '05 FLHTCUI using HD's handlebar mount. After reading the install directions and gulping when it said "refer to your manual for fuel tank removal" I figured there must be an easier way. After searching here I came across the idea of another member using the 2 unused wires attached to the headlight plug. I think these are the wires you are referring to.
I crimped and spliced using a "blue blade" and it worked perfectly. I got power and didn't have to do all the unnecessary wiring. BTW if you look at the wiring manual in the service manual the wires you are referring to are for HDI (International versions) only so are hot and ready to go.
Easy quick job,
FLRYDR
2005 FLHTCUI
Striker62
Aug 17, 2014 06:20 PM
Douf
Jun 20, 2014 08:22 AM
slankard
Jan 10, 2010 10:45 PM
mrbluffo
Mar 1, 2009 05:07 PM
ucommbxny
Feb 8, 2009 08:55 AM
