Old Feb 18, 2015, 05:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
Most motorcycle manufacturers will recommend bleeding the brake fluid in specific intervals. Some members can't remember the last time they changed their brake fluid, others do it religiously.
Brake fluid can absorb moisture over time and affect your braking. Better safe than sorry.
Read the full discussion below to find out more.
Print Wikipost
Who never changes Brake fluid
Old Jan 21, 2015 | 10:16 PM
maryvillept's Avatar
maryvillept
Default Who never changes Brake fluid
Obviously count me in. Grew up in a farm and am old school in thought and what i was taught. Ive never changed brake fluid in my vehicle or bike. I've never had an issue. Likely just jinxed myself but oh well wanted to see if i was alone in my thinking.
Old Jan 21, 2015 | 10:28 PM
1plumr1's Avatar
1plumr1
Me either '03 ultra. Sealed system with minimal fluid movement. If your brakes get hot enough to boil or overheat fluid, you have issues. 125K.
Old Jan 21, 2015 | 10:36 PM
WI Bob's Avatar
WI Bob
In "old School" days that plan worked because the brake fluid was a much different formula. The "new" environmental brake fluids absorb moisture and will eventually damage the system when the water turns to droplets. Might take considerably more than the two years HD recommends changing, but it will get there.
Old Jan 21, 2015 | 11:48 PM
wscott's Avatar
wscott
And that damage can be ABS related which can quickly get expensive epsecially when it's for a Harley!/LOL!!
Scott
Old Jan 22, 2015 | 12:24 AM
decencyxdefied's Avatar
decencyxdefied
I do mine once a year just to have something to do.. Did it last year when i changed my bars and I'll do it again wen I change this bars this year
Old Jan 22, 2015 | 12:38 AM
Peter Griffin's Avatar
Peter Griffin
I had a 94 Wide glide that I changed the fluid out in 09, 15 years later, and I could feel a small difference in the front brake lever.
Old Jan 22, 2015 | 04:04 AM
DHubbs's Avatar
DHubbs
Yes the new brake fluid formulas are different. Absorbing moisture is not one of the differences though. Brake fluid has been known to absorb moisture from the air sence the 1960's or earlier. This is not to say I don't believe changing brake fluids are necessary. I just cant remember the last time I did it,,,,
Old Jan 22, 2015 | 04:49 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Actually, they are not different. Dot 3&4 were and are glycol. They were and are water absorbing. There is no change here for well over half a century. The closest thing to a change is the addition of Dot 5.1, which is also a glycol, but has a higher boiling point than 3 or 4.
Old Jan 22, 2015 | 06:26 AM
DHubbs's Avatar
DHubbs
You are absolutely correct about the boiling points. DOT 5.1 should not be confused with DOT 5 fluids. DOT 5 fluid is silicone based & will not absorb water from the air like the other glycol based fluids. It can not be mixed with them either.
Attached Thumbnails Who never changes Brake fluid-dot-fluid-boiling-points.png
Old Jan 22, 2015 | 07:31 AM
DEW2112's Avatar
DEW2112
I flush mine out and bleed them every few years (2002 bagger,DOT 5). Front brake lever always feels much better when I do this, I think it builds up a little air in the system. Wether its needed or not, its a peace of mind thing and since I do all my own wrenching, its the cost of a bottle of brake fluid. Same with fork oil.
