Faring Replacement Inserts
Old Apr 18, 2007 | 01:34 AM
harleybuilder's Avatar
harleybuilder
Default Faring Replacement Inserts
Does anyone know the outside diameter and thread pitch of the faring replacement inserts? From looking at the inserts, i am assuming that you drill and bottom tap the holes then place a dab of loctite on them.
Old Apr 18, 2007 | 02:15 AM
rm4040's Avatar
rm4040
Default RE: Faring Replacement Inserts
I would usethe old inserts and clean the existing hole in the fairing with a solvent, then use a good epoxy to hold the inserts in the fairing. Do not use lock tight in the treads because that will cause the inserts to break loose again when the fairing is removed.
Old Apr 18, 2007 | 09:37 PM
harleybuilder
Thanks for the help, the replacement inserts are a 3/8x16 NC od. I replaced all 3 of mine today.
$tonecold
May 11, 2014 09:33 PM
rrcrum
Mar 3, 2013 07:35 PM
mwriggs
May 26, 2010 12:08 AM
stro1965
Feb 3, 2009 07:57 PM
MyFirstHD
Mar 4, 2008 12:52 PM
