Repairing Threads in Outer Fairing
Old May 6, 2014 | 01:19 PM
$tonecold's Avatar
$tonecold
Default Repairing Threads in Outer Fairing
I noticed last evening when I was installing the outer fairing on my Road Glide that one of the screws going into the outer fairing never tightened up as the others did. I was just wondering if anyone has been able to repair these threads in this situation or should I just resign myself to using the next larger screw. I would think that a threaded insert or even maybe a helicoil might work and keep the problem from developing again. If you've repaired these with good result I would like to hear about it.
Old May 6, 2014 | 01:35 PM
sbeast's Avatar
sbeast
you have to pop the brass insert out and replace it with a threaded one. harley sells them (i dont remember the part number, look for fairing cover ferrules) or you can take it to a hardware shop and ask them for a ferrule that will fit
Old May 6, 2014 | 01:38 PM
Keithhu's Avatar
Keithhu
there was a thread on roadglide.org where you spray a screw with nonstick cooking spray, then coat the threads on the fairing with jb weld and screw it in. Wait a few hours and unscrew. The cooking spray releases the JB weld and you have nice new threads.
I've never tried it, many claimed it worked.
http://www.roadglide.org/showthread....fairing&page=3
Old May 6, 2014 | 01:52 PM
tOSUSteve's Avatar
tOSUSteve
That thread will have a couple different approaches and tips
Old May 6, 2014 | 02:11 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Yeah... we wish. But we don't have those fancy brass things.
I've used a cut off piece of zip tie with good success.
But here's the easiest fix. Just cut a piece about 1/2 inch long and a little less than 1/4 inch wide.... shove it in the hole, and you're all set. If you want to get fancy, cut two 1/8 strips and try and have them on opposite sides of the hole.
Old May 6, 2014 | 03:50 PM
$tonecold's Avatar
$tonecold
Thanks for the replies. It would seem that the Mr. Grip would be the least expensive and fastest repair. I don't know how permanent it would be, but I'll look at that. I am kind of leaning toward threaded inserts and going to machine screws. I feel I have some time as one screw won't be a big deal right away. There is also some stuff called Plastex that I saw on RG Forum, but it is a little pricey. Thanks again.
Old May 6, 2014 | 04:47 PM
Pappy1's Avatar
Pappy1
Yes....I had to replace 2....Harley sells them....
Old May 6, 2014 | 05:01 PM
fenwick's Avatar
fenwick
hd sells them think they like 7 bucks. it is by far the easiest way and best fix. just did it on mine
Old May 6, 2014 | 05:17 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I was going to say, Road Glide no brass threaded pieces.
Old May 6, 2014 | 05:49 PM
Lakerat's Avatar
Lakerat
Part #16585-96 @2 bucks each. I keep a supply of them in my tool box for all my ham-handed friends.
