LED Tailight
Old Jan 31, 2015 | 12:39 PM
NAILIT RK's Avatar
NAILIT RK
Default LED Tailight
Looking at the led tail light in the HD catalogue. It says it doesn't fit with the license plate relocation kit. Anyone know why? So if I want the Led tail light I have to stay with the big light bar on the back of my Road King? Is HD forcing me to go to Kuryakyn?
Old Jan 31, 2015 | 12:49 PM
mkguitar's Avatar
mkguitar
could be as simple as which way the license plate light is arranged.
you can use Krapkin- if that appeals to you.
for a GREAT taillight a BAL is a great way to go- even better if you find one used.
RK owners sometimes get a streetglide type taillight/signals , there are other options.
you may need a converter for turnsignals if you do that...all depends on which parts you choose, and options will vary depending on your model year.
Mike
Old Jan 31, 2015 | 01:07 PM
NAILIT RK's Avatar
NAILIT RK
Thanks, I would rather stay with HD but they don't make it easy. I think it might be because the Led light is a "lay down style". Parts guy at HD could not answer my question either. I've tried searching here for the street glide lighting but as you say creates wiring issues....
Old Jan 31, 2015 | 01:18 PM
CaCruizin's Avatar
CaCruizin
I fitted a couple of BAL's which are easy to fit, just unscrew the old ones fit the seal and screw in the new ones. Don't look at them too long as they sure are bright!
Old Jan 31, 2015 | 01:28 PM
houstonhdguy's Avatar
houstonhdguy
BAL all they way. No comparison. Pick up a used here.
Old Jan 31, 2015 | 01:31 PM
NAILIT RK's Avatar
NAILIT RK
Ok I did some more searching . Looks like I can use as mentioned above, A 06' - 09' Street Glide turn signal bar. Then order the Lay down led tail light and lay down license plate bracket from the HD catalogue. Seems like a good option, thanks for the reply's
Old Jan 31, 2015 | 01:32 PM
NAILIT RK's Avatar
NAILIT RK
Don't know anything about BAL, will look at them also
Old Jan 31, 2015 | 03:49 PM
SWThomas's Avatar
SWThomas
Don't overlook the Custom Dynamics tail lights.
Old Jan 31, 2015 | 08:51 PM
NAILIT RK's Avatar
NAILIT RK
I think I figured it out. The reason the led tail light doesn't work with the relocation kit is because the tail lights have the license plate window in the top of the lens. (Relocate plate to the bottom and no reason for the window on the top of the lens). Pretty simple...the relocation kit has a lamp in the bottom of the turn signal bar.
Old Jan 31, 2015 | 09:04 PM
jberg's Avatar
jberg
BAL refers to Bright *** Lights. Stupid name but a great product. You won't regret choosing it.
