spark plug wires from fuel motto
Old Feb 5, 2015 | 03:20 PM
Bushy's Avatar
Bushy
Question spark plug wires from fuel motto
I recently ordered new spark plug wires from Fuel Motto.. they are considerably larger then stock// My question is since the old wire holders {zip tie with a plug} I stuffed them well into the tank tunnel and I think far enough from the heads... Since they look like the can stand a few more degrees I hope I;m ok... your thoughts>?? suggestions on new zip ties????
Old Feb 5, 2015 | 03:29 PM
mkguitar's Avatar
mkguitar
I'd ask the vendor how they suggest running/securing them- just in case the wires cann't bend within a tight radius
and 2.) are these wires going to work with the ion sense?
if you see a check engine light, swap back to stock spec wires and plugs
( don't forget anti-seize on plug threads
die electric grease smear on the plug boot
mike
Old Feb 6, 2015 | 01:55 PM
bigheadted's Avatar
bigheadted
I installed a set a few months ago, yes they were a little larger and stiffer than stock but with a very small dab of common mechanical sense they are easily routed as stock ones and with a little manipulation of stock holders fit perfectly. No codes.
Daddywags
Sep 29, 2018 11:39 AM
peddler
Sep 20, 2013 06:34 PM
tmacracin
Sep 3, 2010 02:55 PM
HD-StreetBob2008
Mar 5, 2009 05:37 PM
kelton3
Jul 11, 2008 07:42 PM
