Moving Tourpak Back
Old Feb 5, 2015 | 09:20 PM
bald1der's Avatar
bald1der
Default Moving Tourpak Back
Looking to give momma a little more room in the rear. My tourpak is already in the last mounting hole. Trying to figure out how much further back could I safely move the tourpak without risking ride ability.
Old Feb 5, 2015 | 09:32 PM
mkguitar's Avatar
mkguitar
Dawg has posted a mod with a couple of drilled holes and a couple of bolts...gets you a 3rd position
Mike
Old Feb 5, 2015 | 09:37 PM
dawg's Avatar
dawg
https://www.hdforums.com/forum/touri...ml#post4903837
Old Feb 5, 2015 | 11:12 PM
bald1der's Avatar
bald1der
Thanks!! This is the reason I love this forum.
Old Feb 6, 2015 | 08:47 AM
ALUCARD19's Avatar
ALUCARD19
Go to this place <Ultimate Rider Backrests for Harley- DavidsonŽ Stock Seats>
I made one just like it myself for about half the price but I'm a tool/die maker with access to milling machines.
This is the easiest and it still supports the tour pak all the way just like the tour pak is mounted from the factory.
Old Feb 6, 2015 | 08:54 AM
ALUCARD19's Avatar
ALUCARD19
With this plate you cannot even see it unless you lay on the ground and look up plus your wiring will reach this far without any extensions, it takes only about 20minutes to install.
Just take out bolts from the tourpak and tilt up on the tourpak towards the seat then slide the plate under and rebolt the tourpak through the new plate easy peasy.
It moves momma back 2" making momma happy.
Old Feb 6, 2015 | 05:09 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
I've moved mine back 2 inches, it may affect hadling if… your tour pack is loaded with a large bag on top of the rack and momma on back going uphill, but in a good way u can wheelie all the way up the hill. not a huge problem just be aware.
Old Feb 7, 2015 | 11:04 AM
not yours's Avatar
not yours
My ole lady and I are both around 6ft. I bought a 2011ultra classic the fist thing I bought was a tour pak relocator it has 3 positions
and I moved it all the way back no problem for me and she loves it. She took the pillow under the passenger backrest, bought some
stuffing put it in and wa la perfect. Got it on line but cant remimber were for $99.
Old Feb 7, 2015 | 11:19 AM
madhunter60's Avatar
madhunter60
Kuryakyn 8973 Quick Adjust Tour-Pak Relocator, adjust back up to 3" or forward 1"
plenty of room for momma on the back now,even with riders backrest installed.
BIGBIRD123
Jan 29, 2015 07:06 PM
jma100
Nov 16, 2013 01:38 PM
RPS1981
Mar 2, 2012 12:29 PM
mastery
Jan 1, 2011 01:00 AM
BurgundyUltra06
Sep 1, 2009 10:34 AM
