View Poll Results: Which fork upgrade?
Ohlin FKC 101
16.67%
Progressive Monotubes
40.00%
Ricor Intiminators and Springs
16.67%
RaceTech Emulators & Springs
6.67%
Other
20.00%
Voters: 30. You may not vote on this poll
Fork Upgrade Poll
Old Feb 8, 2015 | 10:50 PM
TSheff's Avatar
TSheff
Originally Posted by SWThomas
Have you tried other fork setups? I haven't, but I've read enough reviews to know that the stock setup is horrible and pretty much anything is an improvement. I guess it's one of those things that you don't know how bad it is until you've tried something good.
I've done the heavier fork oil thing and while it stiffened up the front end, it didn't fix the design flaws. And the ride was very rough on uneven roads.
I've lowered and raised different bikes, done progressive springs, different weight oils, and lots of miles.
You want to upgrade, fine. I haven't done trials with every possible combination and don't have have a test facility. You asked, I answered with my experience, 45 years of riding and a few years of racing. I've not had any issues and I ride fairly aggressively. I'm done.
Old Feb 8, 2015 | 11:10 PM
0ldhippie's Avatar
0ldhippie
Stock is pretty bad, heavier fluid just makes it harsher, progressive springs are little better. Ya need at least some valving, Racetech or Ricor, for better control. I've found Ricor valves marginally better then Racetech, and Racetech springs much better than progressive. With either ya need to mess around with valve settings, fluid types and preload to get it right. Never tried progressive monotubes just because I've never been overly impressed with their shocks?? I'm pretty happy with Racetech springs and Ricor valves from fabrik8r. But may spring for CCE trees to tighten things up?? But I'm getting old and slow...
Old Feb 8, 2015 | 11:33 PM
jefla's Avatar
jefla
You don't need speed to enjoy the CCE upgrade. It'll make your 09 handle like a Rushmore, for a lot less. The 14 and later do have both a clamping upper tree and larger fork tubes, but I believe nearly all the handling improvement comes from the new upper.
Old Feb 10, 2015 | 07:55 AM
SWThomas's Avatar
SWThomas
I just ordered a set of Progressive Monotubes. Thanks for voting and posting comments!
Old Feb 10, 2015 | 08:46 AM
NDBadlands4-2's Avatar
NDBadlands4-2
I just changed my front suspension to the Low version. Have not got to do much more than sit on it so far. I love the change in seat height.
nhrider1
May 9, 2016 04:21 PM
jmn1960
Oct 4, 2015 05:19 AM
jlilnc14
Aug 22, 2012 07:16 PM
sportyscoop
Jul 27, 2008 05:49 PM
Mark g
May 15, 2008 09:14 AM
