for Decent h3 bulbs
Old Feb 10, 2015 | 08:23 PM
decencyxdefied's Avatar
decencyxdefied
Default Decent h3 bulbs for drl
1 of mine went out a few weeks ago in my running lights.. I like the piaa for quality but not gonna spend that kind of money.. I have a truck light and I need a bulb that's not gonna be yellow so that rules out the cheap ones at Walmart.. What are you guys running.. Idk y the title is messed up lol
Old Feb 10, 2015 | 09:23 PM
mkguitar's Avatar
mkguitar
I use sylvania or phillips bulbs.
some bulbs do not hold up well to fluctuations in voltage or vibrations.
h3's comes in various wattages- so match the other side
on some models 55 w may require beefed up wiring or relays ( I did this on my evo)
when kmart was dying ( pre-sears) I bought 2 dozen sylvania 55 w h3 capsules for 25˘ apiece.
mike
Old Feb 10, 2015 | 10:07 PM
bklynbob's Avatar
bklynbob
www.candlepower.com
Old Feb 11, 2015 | 12:26 AM
Hausguy's Avatar
Hausguy
I got something like these - work great and are nice and bright white, not yellow. Can't go wrong at this price for two!
http://www.ebay.com/itm/JDM-881-862-...item58be359ea5
Old Feb 11, 2015 | 04:50 AM
decencyxdefied
Not gonna work for me
Old Feb 11, 2015 | 06:47 AM
grbrown's Avatar
grbrown
My Buell came with Osram H3 bulbs, which seem fine.
Old Feb 11, 2015 | 09:38 PM
Toofat's Avatar
Toofat
I'm using these LEDs in my Kuryakyn spots. They are brighter than the 35w bulb that came in the spots. They put out nice bright white light, probably a good match to your LED headlight. I don't know want kind of spots you have, but if you have 2" between the bulb mount and the lens they will fit. I had to modify the bulb to fit my spots.
http://www.ebay.com/itm/400827993364...%3AMEBIDX%3AIT
Here's some pics.
Attached Thumbnails for Decent h3 bulbs-002.jpg   for Decent h3 bulbs-004.jpg   for Decent h3 bulbs-005.jpg
Old Feb 12, 2015 | 04:50 AM
decencyxdefied
I have the kury drl blinker combo
Old Feb 12, 2015 | 06:50 AM
cyclgoat's Avatar
cyclgoat
Will those LED's fit in my spots on my 09 Ultra?
Old Feb 12, 2015 | 01:44 PM
Toofat's Avatar
Toofat
They will work with a little bit of mods. You have to remove light from mount and remove a little bit of the mount to make it shorter. I just wiggled the light back and forth a little bit. The light came right out of its mount. It looks like you will need a soldering iron to unsolder the ground wire. My ground wire was not soldered. Once the light is removed from mount the material in the red box in pic has to be removed. After material is removed, open ears on whats left of the mount and reinstall light. Bend ears over light, plug light in to make sure it works. If it works, put a little JB weld on it, to make sure light stays in mount.
