recommendations on floating rotors
Old Apr 20, 2007 | 02:27 PM
Jesterphatt's Avatar
Jesterphatt
Default recommendations on floating rotors
Ok I cant take it anymore.. my 06 RoadKingCustom has that annoying squeeking front brake problem back. "The dealer fix of spray foam" didnt hold over the winter.
I went back a few pages but couldnt see any topics on this.
what can you recommend to replace my stock front brakes in regards to the floating rotor system or other?
Thanks for your time, it is appreciated!
Old Apr 20, 2007 | 02:31 PM
Gunkholes's Avatar
Gunkholes
Default RE: recommendations on floating rotors
This is a common complaint with the 06 RK Customs (and probably others). The local dealer here said the best fix was any of the floating rotors; they said they'd install them for free if I purchased them.
I wonder if the 07s have the same issue?
Old Apr 20, 2007 | 02:33 PM
anubisss's Avatar
anubisss
PM calipers and floating rotors. I have the PM calipers...see
http://i50.photobucket.com/albums/f321/anubisss/malibupier013.jpg
Old Apr 20, 2007 | 02:48 PM
Kern's Avatar
Kern
I like the calipers, I just wish PM didnt have to plaster the name all over it. I saw that Hogpro came up with some new calipers the other day that are very clean looking. Nicely priced as well.
http://www.hogpro.com/showsubcat2.ph...mp;subcatid=78
Old Apr 20, 2007 | 03:08 PM
sleepneagle's Avatar
sleepneagle
try the Kevlar pads or Z-pads first. Just a different pad than HD can make a difference. I made the move to floating rotors for other reasons and run Kevlar pads.
Old Apr 20, 2007 | 03:53 PM
Primo's Avatar
Primo
The floaters from H-D worked fine for me on my '05 and '06 with no other modifications.
Running solids now only because they match my wheels.
Primo
Old Apr 20, 2007 | 05:15 PM
tireater's Avatar
tireater
Pretty sure there is a recall on the dual front brake set up...they reverse the discs...make sure they are true next with felt pen...
If not..largd adj. wrench or rubber mallet will fix it..I SAW THE FACTORY BULLETIN ON THIS ONE...
Old Apr 20, 2007 | 06:57 PM
Mr Wonderful's Avatar
Mr Wonderful
The HD pads are very hard. Lyndall pads are excellent and Kevlar.........advise you to try them first. The floaters are wonderful.......stock on many non-Harley bikes. Use the Lyndall pads AND the floaters for a sure thing....and the kevlar pads won't scar your rotors.
Old Apr 20, 2007 | 09:10 PM
rallymedik's Avatar
rallymedik
Primo...Sweat Ride BRO
Old Apr 20, 2007 | 09:57 PM
Primo's Avatar
Primo
ORIGINAL: rallymedik
Thank you. That's a pretty nice setup you're riding yourself.
Primo
