Newbie Question
Old Mar 12, 2015 | 09:33 AM
Bobt1965's Avatar
Bobt1965
2nd Gear
Default Newbie Question
Just picked up my first Harley yesterday, 2009 Ultra classic...have what I hope is an easy question.
I am looking to set up a phone charger with hook up to the radio in one of my lower fairings.
Any tips/instructions on how to DIY this and how tough will it be?
Any help is appreciated.
Old Mar 12, 2015 | 09:37 AM
mkguitar's Avatar
mkguitar
Welcome to the Forums
And to the New ride.
on my 09 I use an iSimple interface and the iphone in a fairing pocket or magnetic tank pouch.
an easy place to draw power is the unused European-Spec position light wiring- orange/wht is +, blk is negative- this is atttached to the headlight wiring plug- it comes on with the ignition.
mike
Old Mar 12, 2015 | 09:59 AM
Bobt1965's Avatar
Bobt1965
2nd Gear
thanks, is there a specific ISimple interface you used and does it allow you to scroll music via the Harmon / handlebar controls? If so can you share the info
Old Mar 12, 2015 | 10:03 AM
mkguitar's Avatar
mkguitar
no, it a $25 audio interface that charges the phone too.
HD makes an ipod/iphone interface which allows scrolling via the handlebar buttons, but I don;t have it- I test rode a bike with and use required way too much time with eyes off the road
iron cross audio is another source.
you use apple or....
mike
Old Mar 12, 2015 | 10:52 AM
cncmike's Avatar
cncmike
There are a lot of different companies that make handlebar mounts for phones. Get a SHORT cigarette lighter charging adapter and a cord to go from your headphone jack to the auxiliary port on the front of the radio. I listen to pandora until I travel somewhere without a signal then I switch to music I have on my phone.
Old Mar 12, 2015 | 10:54 AM
Bobt1965's Avatar
Bobt1965
2nd Gear
Dont disagree with eyes off the road.....your set up hooks to the back of the radio?
IE I dont want to wire to aux hook-up on front.
Old Mar 12, 2015 | 11:05 AM
Bobt1965's Avatar
Bobt1965
2nd Gear
Thanks for tip, but dont want my iphone on the handlebars....to much temptation to look at mess with it while riding.
I am looking to hardwire/hook into the back of the radio and sit my phone in the lower fairing. Out of site..........while it would be nice to use the handlebars to fast forward/skip...i can do without that and just use volume
Old Mar 12, 2015 | 02:08 PM
Colorido's Avatar
Colorido
Easiest and cheapest solution is a hogtunes 4 pocket windshield pouch. It has grommets for feeding aux cable and usb cable through on each end. Run usb to charger in cigarette port and run a short aux cable to radio through other end.
You won't be able to easily change songs, but you can change the volume with the handlebar buttons.
I use this set-up because i'm a cheap skate and it works just fine. On deserted roads in the middle of nowhere, I will sometimes pull the phone out and change music. But usually, my playlists are perfect.
Old Mar 12, 2015 | 02:13 PM
dibe's Avatar
dibe
Your only options to change the songs from the handlebar controls would be the HD iPod interface or the Iron Cross one. I installed the Iron Cross interface on my bike over the winter. It has worked fine when I have messed with it in my garage. Haven't had the bike out with it yet tho.
Old Mar 12, 2015 | 02:16 PM
pp6000v2's Avatar
pp6000v2
If you're looking to do exactly as described, just connect a phone and let it play music, you can use the unused position light leads to wire in a cig outlet that stays tucked inside the faring, then run a longish cord up to the radio through the faring. You'll already have the front of the bike off, take a few minutes and unbolt the radio from the supports so you can pass the audio cable through to the front of the faceplate; this way the audio cable is as hidden as it can be.
If you still want access to the phone while you're moving, definitely go the route of running a power wire up to the windshield bags if you have them. I personally use a bluetooth adapter that's wired into the radio's aux input, so the only wire I have to connect is power when I need it.
Blue Tick
Audio Systems
Jun 4, 2018 08:35 PM
cubalz
Jul 27, 2016 05:42 PM
h-d wrencher
Audio Systems
Mar 30, 2015 12:40 PM
leeinmemphis
Feb 28, 2008 12:53 PM
hdtaxman
Jun 7, 2007 11:45 PM
