Fuel Moto Head Pipe Issues
Old Mar 14, 2015 | 04:40 PM
stubby001's Avatar
stubby001
Unhappy Fuel Moto Head Pipe Issues (Pix Added)
Just not my day. First my new in the box Premium Ride H-D Shocks are 2 different lengths (12"&13") Went on to installing Fuel Moto head pipe and it is hard against the cam cover and I see no way to adjust it so it doesn't touch. There should be a little space correct? Yes I will take a little cheese with my wine.
Old Mar 14, 2015 | 04:48 PM
FinalShot's Avatar
FinalShot
hard against the cam cover? You probably don't have it lined up correct or something. Is it underneath the bracket there under the cam chest? I have the Fuel Moto Jackpot header and have no issues. I know hundreds here that have it too.
Can you take pictures?
Old Mar 14, 2015 | 05:21 PM
stubby001's Avatar
stubby001
Will try to post some pix later.
Old Mar 14, 2015 | 05:37 PM
Bikerscum's Avatar
Bikerscum
Someone just posted about this issue in the last couple of days... I think they said they were sent a new pipe with a different bracket.
Old Mar 15, 2015 | 08:36 AM
stubby001's Avatar
stubby001
Here are a couple pix.
Attached Thumbnails Fuel Moto Head Pipe Issues-pipe-1.jpg   Fuel Moto Head Pipe Issues-pipe-2.jpg
Old Mar 15, 2015 | 09:52 AM
equandt's Avatar
equandt
If you call Fuel Moto, I think you'll find they will be very helpful to resolving your issue.
Old Mar 15, 2015 | 09:53 AM
Northbound Southerner's Avatar
It doesn't look like the headpipe is seated in the heads correctly. What gaskets are you using? Are you certain you got the old ones out? Fuelmoto pipes are very close on tolerances when installing. If you are certain your gaskets are properly seated, loosen the head bolts and give it a good wiggle. It will snap right in.
Old Mar 15, 2015 | 11:10 AM
ndnguyd's Avatar
ndnguyd
Have installed a few of these and they do kinda pop into place, You will know it once its in.
Old Mar 15, 2015 | 12:08 PM
ultraclassic53's Avatar
ultraclassic53
That sucks, Stuff always happens on the weekend when you cant talk to anyone,
What I would do is pull them back off and take off the flanges that you put the studs thru so i could see how far they are settling into the gaskets.
It looks to me like the rear one is not goinbg in. its causing the pipe to be pulled back towards the cover.
Old Mar 15, 2015 | 12:42 PM
FinalShot's Avatar
FinalShot
Just a stupid question, did you take the snap rings off your old header and move them over to the new one?
