05 flhtcui
Old Mar 20, 2015 | 03:23 AM
DRILLER157's Avatar
DRILLER157
Stage II
Default 05 flhtcui
What can I do to it to get it to preform better wit miner details
Old Mar 20, 2015 | 05:45 AM
just plain john's Avatar
just plain john
Need a bit more detail. Is it stock? What does "perform better" mean to you? What is your budget? Generally speaking, the first performance upgrades are a free flow air intake, better flowing mufflers, and a tuner module. Depending on the selection of components, you can expect to pay close to $1000. When you hear the term Stage 1 it means the mods listed here. Next would be a cam swap, then a big bore kit. There's a good chance you have one or more of these parts already. Pull the side cover and see if there's a device plugged into the ECM.
Old Mar 20, 2015 | 06:24 AM
grbrown's Avatar
grbrown
Minor details won't give you much extra performance, but new cams and a big bore cylinder kit can really light up your bike.
Old Mar 20, 2015 | 08:54 AM
SafetyMan's Avatar
SafetyMan
Welcome aboard.
Easiest is buy a 2015. You'll be happy.
Old Mar 20, 2015 | 09:00 AM
howitzer88's Avatar
howitzer88
After the stage 1 as noted above, look into replacing the rear suspension with some Ohlins and change the fork oil to slightly heavier. It will feel like a different bike.
Old Mar 20, 2015 | 09:11 PM
rdam's Avatar
rdam
I had an '05 with Screaming Eagle Air Cleaner, Stage 1 Download, V&H True Duals, Supertrapp SE II mufflers, and Andrews 21G Gear Drive cams.
By far, the most improvement in performance was gained with the cams.
Old Mar 20, 2015 | 09:33 PM
PapaThiele's Avatar
PapaThiele
Welcome from NoCo! Like someone else said, we need to know whats been done so far.
jmb79
Feb 6, 2022 07:12 PM
John.E
Jul 19, 2019 01:52 PM
caulk04
Mar 4, 2017 02:20 PM
kmille
Apr 27, 2014 09:12 PM
fwb35
Nov 4, 2012 01:34 PM
