radio reception
Old Mar 21, 2015 | 10:07 AM
tinsnips's Avatar
tinsnips
Default radio reception
well ,the FM reception on my 08 ultra radio just went away. Tried hiding the antennae under the seat. put the antennae back and then no more reception.
Old Mar 21, 2015 | 11:02 AM
mkguitar's Avatar
mkguitar
check your wiring...did the antenna get damaged?
mike
Old Mar 22, 2015 | 11:21 AM
tinsnips's Avatar
tinsnips
Ive tried 2 different antennas good call on now checking the wiring under the seat. problem is that 1 station still comes in strong
Old Mar 22, 2015 | 12:02 PM
HzrRock's Avatar
HzrRock
Had same problem on an '08 Ultra. Found a nick in the antenna cable insulation up by the forks. Bought a new cable from dealer and it fixed the problem.
Old Mar 22, 2015 | 12:39 PM
mwegryn's Avatar
mwegryn
Definitely check your cable and connections, has to be something simple.
Old Mar 22, 2015 | 12:45 PM
hellbilly78's Avatar
hellbilly78
I cut about a 1/4 of the length off of my 12 sg antenna and slid it into the tunnel of the tank and it still works great. Check and make sure the cable is plugged in tight
Old Mar 22, 2015 | 03:35 PM
z71_fourwheelin's Avatar
z71_fourwheelin
Where the antenna mounts is a 3 piece assembly. Check the connection underneath where the antenna wire plugs into the adapter
Gone Blue
Audio Systems
Oct 4, 2016 07:29 AM
Shark.Glide
Mar 29, 2015 09:23 PM
jimmydon
Jul 22, 2013 10:33 PM
OD_Cleaver
Apr 10, 2009 09:18 AM
mike5511
Nov 21, 2007 05:59 PM
