CB Radio
Old Nov 19, 2007 | 02:36 AM
mike5511's Avatar
mike5511
Default CB Radio
Anybody tried to do anything to make the CB radio work better? If so, what did you do and how big of an improvement did it make? I am real curious about the SWR readings: are they low enough right from the factory? Any info will be appreciated!
Old Nov 19, 2007 | 06:10 AM
TexasRedneck's Avatar
TexasRedneck
Default RE: CB Radio
Mine were, but ah'd not bet on 'em bein' so. First, make sure the antenna is on the proper side, then check 'em.
Old Nov 19, 2007 | 06:54 PM
Hawkeye's Avatar
Hawkeye
TR -
Funny you should mention making sure the antennas are on the right side. I was cruising through my local dealer the other day, just killing time, checkin' out the '08 Ultras. Something was weird about one of them but I couldn't put my finger on it. Every time I walked away from it I had to go back because it bugged me. Then I noticed it: CB antenna and radio antenna were reversed! The other four had them correct but they were switched on the one. Yikes!
Old Nov 19, 2007 | 07:21 PM
Nellybelle's Avatar
Nellybelle
OK sitting on the seat facing forward what side should the CB ant be on?
Old Nov 19, 2007 | 10:48 PM
goodbirds's Avatar
goodbirds
Right side. Check under the trunk insert for the coil and metal ground plate.
Old Nov 21, 2007 | 01:03 AM
mike5511's Avatar
mike5511
Thanks for the info. CB used to be a hobby of mine, I was curious as to what I can expect when I get my new Ultra.
Old Nov 21, 2007 | 07:33 AM
Doug45601's Avatar
Doug45601
ORIGINAL: mike5511
Depending on your location and CB activity... don't expect much! The CB radio combination isn't all that compared to a stand alone CB radio. It will pickup close by receptions and transmitte close by.. You may even pickup some "skip" from time to time but won't work very well for in town traffic.
Old Nov 21, 2007 | 03:05 PM
oneshotdog's Avatar
oneshotdog
I intially tried cb, it was lousy old technology and new just didn't clash, ended up going to gmrs radios, way better quality
Old Nov 21, 2007 | 03:13 PM
rvisdew's Avatar
rvisdew
I like the way the stock CB radio works ... I get at least a mile maybe two, which is perfect when riding with a group.
Just traded in a bike with the J&M CB which wasn't nearly as good (but then, that bike didn't have a 'plate' to help reception).
Old Nov 21, 2007 | 03:25 PM
cirhere2's Avatar
cirhere2
it will suck
