Buying a 'Glide... which one? whch year?
2007 bikes - new hydraulic cam tensioners fix the problem in older bikes.
2008 bikes - kind of a transition year. Several upgrades including throttle by wire and larger tanks.
2009-2013 bikes - new frames, new brakes (vastly improved), 6 gallon tank from 2008 carries over into the new bikes, larger back tire. The improved handing is significant and these are great bikes. If funds are tight, these bikes can be had for very reasonable prices.
2014 bikes - Rushmore series improvements are vast. Upgrades to the front suspension, redesigned fairing, new Infotainment system with GPS and large touch and voice enable screens. The Ultra Limited's and CVO's come with the twin cooled motors. Linked brakes improve upon the 2009 upgrades. Several recalls early on, but all seems well now. Personally, there are enough improvements in these bikes that this is what I'd recommend if you can afford it. The Ultra Limited is probably the best bang for the buck.....nicer wheels, painted inner fairing, twin cooled motor, etc.
You have asked what is known as an open question, which isn't easy to answer. You would do well to visit a local dealer or two to see what they have in stock and ask us specific questions about a given bike.
The only thing I would add is if you are doing any distance riding look for cruise control. I can remember when you had to go to the ultra to get cc as stock.
I don't know the current models that it is standard equipment but someone may be able to add this information. I had cc added to a 97 tour-glide and it was expensive. I currently have it on my 12 Streetglide ad I believe it was stock on this year and model.
