Cop bike wire ?s. thumb control
Old Mar 29, 2015 | 05:00 PM
dodger413's Avatar
dodger413
yep, it's a police bike.
looks like someone removed the sliding red pursuit switch and replaced it with the cruise control. bummer.
good luck
Old Mar 29, 2015 | 07:26 PM
Juice's Avatar
Juice
Originally Posted by BlackPearl#1
2011 FLHTP
A few pis attached but ultimate question is where are the leads from attached picture of thumb control? When you push it either up or down, not sure what one, the pursuit light "P" comes on the speedo. There is an empty plug, pic also attached, in the fairing but I tested them with test light and got nothing when running the thumb switch. If crappy phone pic isn't good enough, the switch is as follows. Top is up, middle is mode sel, and bottom is dn. Any input is appreciated.
Kris
The empty plug is for heated grips.
Old Mar 29, 2015 | 09:01 PM
BlackPearl#1's Avatar
BlackPearl#1
Ok thanks. Someone has to know where those leads from that switch go because that P lights up when yo hit the control on the right side.
Kris
Old Mar 30, 2015 | 07:18 AM
BlackPearl#1
Morning guys have any input?
Old Mar 30, 2015 | 06:19 PM
Timmer008's Avatar
Timmer008
The "p" in the Speedo stands for pursuit and would indicate your passing lamps are on which would of been the red and blues when it was a cop bike and that switch is still going there probably. When you hit that switch do you side lights turn on and off?
Old Mar 30, 2015 | 06:31 PM
87gtNOS's Avatar
87gtNOS
I have an 09 FLHTP...I just went and double checked, my sliding switch turns on the P on the gauge in the middle position, and pushed all the way on the P stays lit up and the auxiliary (formerly pursuit lights) lights turn on.
I was hoping to make the rocker on the left controls capable of turning off my AutoTune. However, that would require major re-wiring as it's tied into the other switches too!
Phallocrat
2014-2024 Touring Models
Sep 9, 2017 06:14 PM
papabear64
Aug 23, 2017 06:43 AM
1st 96 ultra
Apr 6, 2011 07:20 PM
greglcarlson
Feb 11, 2011 01:34 PM
NitroBerserker
Dec 16, 2006 07:53 PM
