tired speaker upgrade
Old Mar 29, 2015 | 12:03 PM
Roadie13's Avatar
Roadie13
Anything would be better than the stock speakers, but to be honest with you I'd just wait. Even if you go with 6.5s they will sound a little better in the garage, but after you get used to them your ears will be bored again soon. Save your coin until you can pick up a cheap amp and speaker take offs and you'll be much happier. I started by just upgrading speakers, soon realized I really needed an amp to wake them up and then finally got smart and went the full biketronics route and won't need another upgrade. You can probably pick up a pair of Kappa 62.11s, adapter rings, and a PBR 300x2 used off the forum or fleabay for under $200 shipped and that would be a million times better than just spending $50 or $75 on speakers and not having an amp.
Old Mar 29, 2015 | 02:21 PM
HD_Doobie's Avatar
HD_Doobie
Originally Posted by bigmarc66
$100 if its life changing, really need to be around $50, i use ebay for most things, it was my understanding that any old 6.5" speaker will not work because they require 4ohms, which is why i thought stock hd 6.5" speakers would be a good choice being they are 2ohms
Simply swapping speakers is not going to be life changing. You WILL need and amp to wake them up. My recommendation is to wait and save some more money. Throwing a $50 set of speakers in is going to be a waste of $50 you could put towards sme better speakers. If you really want to change speakers put a set of Infinity Kappa 62.11i's in. At $110 they will be a slight improvement over stock without being amped. At least them you are ready for any future amps, Rockford Fosgate pbr300x2, Cerwin Vega B2, etc..
Edit.... FYI the Kappas are 2 ohm
Old Mar 29, 2015 | 02:39 PM
Tinman265's Avatar
Tinman265
Originally Posted by Schrauty
Take a look at the Polk db651 speakers (Crutchfield is a good place to start). A lot of folks have had good results with these and they run about $75 for a pair.
I used the Polk MM651. I think they are a better fit as well as a better speaker.
2.7 ohms and more efficient. No loss of volume due to slightly higher ohm rating. And they will fit in the rear speaker pods with only new screw holes needed.
Old Mar 29, 2015 | 03:51 PM
dirtdobber's Avatar
dirtdobber
You can get caught up in trying to figure out what you may like. No 2 set of ears are the same. So it's subjective.
I tried so many amps and speakers it was getting old.
If you are limited on funds I would consider 6.5 alpine speakers. You want the 45/50 watt rms. you will lose a slight amount of volume but the clarity improvement is great. On a motorcycle there will be little bass when riding. The bike tronics are pretty good. Got a set that I had on my 07 laying on a shelf. Traded bikes, CVO street glide. I ,love the sound of the boom system. Good luck with your venture.
Old Mar 29, 2015 | 06:22 PM
WB's Avatar
WB
6 1/2 speakers will be a waste of money without an amp.
Old Mar 29, 2015 | 10:18 PM
0ldhippie's Avatar
0ldhippie
As a rule: Better speakers will provide clearer sound. More power will provide more undistorted volume. 4 ohm speakers will eat what little power ya have providing less volume. Infinity/JBL make good 2 ohm speakers.
pacemakertom
Audio Systems
Jan 26, 2016 07:18 PM
Diggman
Audio Systems
Sep 27, 2013 10:44 AM
wilcoxracing
Apr 24, 2011 07:33 PM
Chula
May 15, 2009 10:02 PM
bgrasn
Apr 30, 2007 09:37 PM
