Road Glide Handlebar replacement
Old Apr 23, 2007 | 05:11 PM
Mikind7's Avatar
Mikind7
Default Road Glide Handlebar replacement
Any tips/ tricks to changing Roadglide bars? Going with Wide Glide Bars....
Old Apr 23, 2007 | 05:20 PM
soberglide's Avatar
soberglide
Default RE: Road Glide Handlebar replacement
Just pop cover off speedo/tach. Press base below speedo forward with thumbs far enough to release two tabs. Pivot cover forward to unhook at top. This will reveal handlebar clamps and top bolts. Take a dremel or similar tool and trim the lower part of nacelle to allow access to lower bolts. Speedo cover will hide when reinstalled.
BTW check heritage classic bars before you decide for sure.
Tim
Old Apr 23, 2007 | 05:34 PM
soberglide's Avatar
soberglide
oops, forgot! there is a torx head screw on each side of the speedo tach cover.Better remove those or you won't get too far. 25torx I believe.
sorry
Tim
Old Apr 23, 2007 | 05:56 PM
gunrunner's Avatar
gunrunner
Bars from a Heritage or wide glide will work with some munipulation of wires and cables without changing them, a search on this subject will give you step by step info. I ran both and found heritage the best for me.
Old Apr 23, 2007 | 06:22 PM
Mikind7's Avatar
Mikind7
Was more concerned with the complications at the contol end of bars, will parts fly when I open them up? Looked in the service manual and of course they make it sound like a major project. thanks for all the help...
Old Apr 23, 2007 | 06:56 PM
soberglide's Avatar
soberglide
No parts to fly around when you split controls. The most tedious part will probably be the throttle cable ferals. Adjust cables out to give you maximum slack, then readjust after installation.
Tim
Old Apr 23, 2007 | 09:33 PM
Mikind7's Avatar
Mikind7
OK Got the bars on, don't know why they intimidaed me, I've changed many bars before, I think all the radio controls etc had me in a corner...no sweat, about an hour and a clutch cable reroute,done deal, and everything still works!Thanks all for your support.
Daddy454
Feb 8, 2017 08:25 PM
emerican19
Dec 19, 2012 12:01 AM
scooter4
Feb 25, 2012 07:34 PM
Stryke1
Nov 17, 2007 03:36 PM
Dizzzy
Nov 3, 2007 01:17 PM
