ABS light
Old Apr 22, 2015 | 11:23 AM
elwoodto's Avatar
elwoodto
Angry ABS light
Hi everyone
I have a 2010 Ultra Classic Limited with a ABS light on. I found the a broken wire in the wire harness on the left side of the the neck. Fixed that and the light went off for a few seconds and started blinking like its supposed to and then it came back on solid. Checked continuity in the wires from the ABS module to the ABS sensor and it was good. Checked the codes and it said open or shorted wheel sensor. Replaced the ABS front wheel sensor and it worked ABS light blinked just like it supposed to. That was last night, this morning I go out to move the bike and the ABS light stayed on solid. I erased the code/light (front wheel sensor again) with my Power Vision and the light comes right back on. I'm gonna pull the tank off and check for a pinched wire?
Help
Old Apr 22, 2015 | 11:39 AM
SBates08's Avatar
SBates08
Try erasing the code via the instrument panel. I've had occasions where the PV wouldn't clear the code.
2010 Limited with some stuff
Old Apr 22, 2015 | 02:43 PM
EricD10563's Avatar
EricD10563
Had a similar problem, the ABS wire had pulled out from the connector on the left side of the neck. HD had zip-tied the wire causing stress on the wire/connector when the bars were turned. I reattached the wire and cut the zip-tie and it went away permanently.
Old Apr 25, 2015 | 10:29 AM
elwoodto's Avatar
elwoodto
Default Abs light fixed
Fix the abs light. Evidently my buddies ohm meters test probes where to big. They depressed the tabs in the abs wire connector and it wasn't making contact. Replaced both wire connectors inside the plastic connector and it's fixed.
C908
Mar 12, 2026 09:32 AM
sudz55
Jul 17, 2014 11:24 PM
shore
May 1, 2013 02:47 PM
1fathog
Mar 22, 2013 07:21 AM
HOGinit
Jul 29, 2008 05:19 AM
