Brake pads
Old May 1, 2015 | 09:26 AM
pretz's Avatar
pretz
Default Brake pads
So its that time for me to change the brake pads on the SG. My question is simple. because of the reservoir position on the handle bars, do you change the pad while the bike is on the jiffy stand or is it better to do on a wheel choke?
Old May 1, 2015 | 10:07 AM
TWIN CAM 96's Avatar
TWIN CAM 96
I'd do it on a lift to make the bike level.
Old May 1, 2015 | 10:39 AM
harleyguy5571's Avatar
harleyguy5571
I also wrap the surrounding arena with masking tape just in case a little fluid comes out. Break fluid is nasty on painted surfaces.
Old May 1, 2015 | 04:53 PM
stic2it's Avatar
stic2it
Jiffy stand, the brake fluid reservoir is level leaning to the side. With the wheel to the left but it also depend on your bar setup
Old May 1, 2015 | 05:09 PM
Notgrownup's Avatar
Notgrownup
I change them on the lift but only with the front lifted...
Old May 1, 2015 | 06:07 PM
just plain john's Avatar
just plain john
If you're just doing pads it doesn't matter, there's no need to bleed the brakes unless the puck comes out of the caliper.
Old May 1, 2015 | 09:13 PM
14GuineaPig's Avatar
14GuineaPig
I change pads with the bike on the jiffy stand. No reason to open the master cylinder, just push the pistons back into the caliper. If you're concerned about brake fluid coming out of the master cylinder you could wrap a rag around it to prevent any fluid form leaking onto the paint.
Old May 3, 2015 | 10:05 PM
pretz's Avatar
pretz
So if I do not remove the reservoir lid and begin to compress the pistons back-in, it won't cause any issues as the reservoir begins to refill from the fluid in the lines?
Old May 3, 2015 | 11:41 PM
SH_01FXDWG's Avatar
SH_01FXDWG
I think you need to remove the cap to be able to compress the pistons back in. You won't need to bleed the brakes. Be aware that some may (probably will) come out. Do yourself a favor before hand and apply a fresh coat of wax on areas you think could get splattered on. Also cover with towels. I just changed my bars/cables and some got on my paint. Wiped it up right away. No problems.
Old May 4, 2015 | 06:41 AM
Neil's Avatar
Neil
You can leave the cap on and I would recommend that to keep the fluid from getting all over the paint. Slowly work the pistons back into the caliper. If you have added fluid at some point you will need to remove it. If you take the cap off you will have to be hyper vigilant to make sure the fluid doesn't spill. If you push pistons in too fast it will create a lovely little fountain in the reservoir that will create havoc with your paint. I would take this time to flush the fluid with new anyway.
Neil
RDMC
