progressive 970
Old May 14, 2015 | 12:13 PM
tj316's Avatar
tj316
Originally Posted by greggmig
I was going to get Ohlins I did my research and came to the conclusion that almost every year I would have to rebuild them at a couple + hundred bucks the 970's have a lifetime warranty and I have dealt with Progressive Suspension before and they have excellent customer service
You better check again , their lifetime warranty is against material defect , IT DOES NOT COVER NORMAL WEAR AND TEAR , which is why you would rebuild a shock , with these shocks you would still want to rebuild them periodically
Old May 14, 2015 | 02:25 PM
dibe's Avatar
dibe
Thanks again for the additional info greggmig. I feel the same about have to drop an additional couple hundred every year or so to rebuild the shocks on top of everything else needed for these pigs.
Old May 14, 2015 | 03:25 PM
bagman1's Avatar
bagman1
Originally Posted by dibe
Thanks again for the additional info greggmig. I feel the same about have to dro byp an additional couple hundred every year or so to rebuild the shocks on top of everything else needed for these pigs.
Why do you feel you would have to rebuild your shocks every year?
Old May 14, 2015 | 07:07 PM
dibe's Avatar
dibe
I'm not sure on the exact mileage off hand but I guess the Ohlins are suppose to be rebuilt every so often.
Old May 14, 2015 | 09:09 PM
tj316's Avatar
tj316
What don't you understand ? Progressive shocks will have to be rebuilt too , no shock is designed to use forever without rebuilding it. You have moving metal parts inside them , this contaminates the oil along with heat breaking it down , if you don't rebuild them they will quit working effectively . The only difference is Ohlins tells you they need to be rebuilt up front , Progressive doesn't but when they stop working and you send them back they will be rebuilt and you will be charged because this is normal wear and tear , read the warranty.
Old May 14, 2015 | 11:46 PM
bagman1's Avatar
bagman1
I looked them up on line and besides the price being over $1200, thats more than a couple hundred over the 944. I also do not like where they put the reservoir, to me thats in harms way, especially from the passengers foot. I wonder if you could turn the shocks around and mount it behind the bags like Ohlins does.
Old May 15, 2015 | 08:37 AM
BDMastiff's Avatar
BDMastiff
I regretted buying my 970's until I got them dialed in. I did the install in my driveway with a bit of help from my friend. My buddy already had 970's so we set the springs the same as his. Well, he weighs 100 lbs more than me. My bike was unstable and wobbling though the twisties. I finally tightened the springs and dialed in the dampening. I love the shock and I love that I can adjust them on the fly. I don't think the reservoirs are ugly or intrusive. In fact, people are always asking me about the reservoirs.
Old May 15, 2015 | 09:16 AM
dibe's Avatar
dibe
There isn't anything about that I don't understand. I was just responding to bagman1.
Old May 15, 2015 | 09:17 AM
dibe's Avatar
dibe
944's on Amazon are about 650 while the 970's are around 850. Both from Amazon.
Old May 15, 2015 | 11:32 AM
greggmig's Avatar
greggmig
I have sent shocks and mono-tubes back and they have never charged me always have had great customer service, don't know if their policy has changed. For what you pay for these I'm sure replacement is factored into the price just like automotive shocks however auto shocks are a fraction of what bike shocks cost.
