2009 roadking noise
Old May 16, 2015 | 09:23 AM
athyjl's Avatar
athyjl
Stage II
Default 2009 roadking noise
I have a 2009 Roadking. It started making a weird noise in the front. Once i get going it does not make it anymore. It sounds like something is loose. It only makes it at very slow speeds. It does not feel and different whith its handling. Just seeing if anyone has has this happen to them. Before i go to a Shop.
Old May 16, 2015 | 09:30 AM
jeffreydsilver's Avatar
jeffreydsilver
Default Fwiw
My 09 Road King had a catastrophic front wheel bearing failure at about 11,000 miles. If you haven't looked at the front wheel bearings you should take a peek. They are sealed with a rubber type cover between the outer and inner race. They will sometimes show grease leakage or even a total seal failure. This visual inspection takes only seconds. These are a roller type bearing that have a history of failure.
Randy Petty
Jun 13, 2018 11:04 PM
Sc0-
Engine Mechanical Topics
Apr 6, 2017 12:23 PM
JINX57
Nov 30, 2016 01:16 PM
Sc0-
Nov 29, 2016 09:04 PM
neversatisfied
May 8, 2014 01:02 PM
