ACC Button
Old Apr 26, 2007 | 11:56 AM
huskers11's Avatar
huskers11
Default ACC Button
I have a 2007 road glide and I was wondering what I can hook up to the acc switch. Also, where do I plug things in at to run off the ACC switch?
Thanks.
Old Apr 26, 2007 | 03:12 PM
the_icemAN's Avatar
the_icemAN
Default RE: ACC Button
Not entirely sure about the RoadGlide. Only can say what I remember about my 07 Ultra.
I haven't hooked anything up to my ACC switch but I do believe the power for it is under my saddle. Assumption made it would be in the same location on the RoadGlide.
You would have to pull one of your saddle bags (right is easier to pull since it is a little higher up when on the Jiffy Stand)
Unbolt the strip over the Saddle
Unscrew the mount in back of the saddle (Philips Head) and it is kinda a pain to get to with the tour pak /rear backrest in the way.
lift out the seat
and I'm 90% sure the accessory plug is there near the battery.
Could be wrong about the placement and I'm sure I will be 'gently' corrected if I'm wrong or will be confirmed.
Dunno what the power looks like for the accessory and what plugs into it 'stock'.
Old Apr 26, 2007 | 03:20 PM
rollover's Avatar
rollover
It's under the seat on my 06 Ultra. I have my heated seat plugged into the switch.
Old Apr 26, 2007 | 03:28 PM
jbhawley's Avatar
jbhawley
many things can get plugged into the harness
There are 4 plus w/in the connector.
2 are hot all the time (basically straight wired to the battery)
2 are controlled with the ACC switch and are only hot if the ignition is on or the ignition swithc is in the ACCES position.
I have my tour pak interior lights wired to the ACC switch.
Almostinvincible119
Jul 11, 2023 03:38 PM
GzrGlide
Jul 25, 2010 10:16 PM
HOGNOT
May 15, 2010 02:41 PM
biz44
Nov 20, 2007 11:27 AM
Edmo
Jul 4, 2006 03:55 PM
