01 RKC starting ?
Old May 21, 2015 | 06:17 PM
Mac459's Avatar
Mac459
Default 01 RKC starting ?
Whenever I go to start the bike I let the pump run and wait roughly 2 seconds after then go to start the bike..this is where my "trouble" starts
It will start to roll over then stop for about a second then it will just crank on over..but for that 1 second the bike does nothing..no clicking, no trying to start..just complete silence..then it starts right up
Is this due to the high compression of the motor..or is it something else..it's never failed to start or even struggled to start up after the initial pause
Any help will be greatly appreciated
Old May 21, 2015 | 06:24 PM
mkguitar's Avatar
mkguitar
high compression or battery/cables
if you listen to the starter you will hear a whining.
this is the insulation burning on teh windings...once the smoke comes out a pricey fix.
try:
flick the starter button with your thumb
it will either push the piston past TDC or rebound back down the bore...either way the piston will be able to build some speed for the next compression cycle.
then press and hold the starter button- if the starter stops turning release the button
motors ALWAYS stop on the compression cycle.
if you have increased compression, add compression releases
mike
Cingcat
Apr 26, 2017 07:48 PM
HOGNIT
Jun 15, 2015 04:21 PM
Lumpy Schmidt
EVO
Aug 29, 2012 08:05 AM
ironhead3fan
May 6, 2011 09:18 AM
6 gun
Exhaust System Topics
11
Mar 28, 2010 07:27 AM
