Fuel pump?
Old May 30, 2015 | 12:02 PM
xcbullet's Avatar
xcbullet
Default Fuel pump?
My new to me 99 flhtci justs had trouble starting. The fuel pump didn't come on. The light flashed 9 then 3. Not sure if this is a wiring issue, I did just put a PC3 in it a few days ago. Thinking its the pump as it don't sound to good. Any insight would be great. Would like to fix before becoming stranded.
Old May 30, 2015 | 12:39 PM
BoonDock_Saint's Avatar
BoonDock_Saint
Bypass the PCIII first and go from there.
Old May 30, 2015 | 12:43 PM
Stiggy's Avatar
Stiggy
And check your bank tilt sensor on the left side attached to the frame under the side cover. I replaced my fuel pump before I realized that the tilt sensor was screwing with it. You can disconnect it and then ground it to check it. You may get an engine light but the bike will run strong. $62 at the Dealer.
Old May 30, 2015 | 12:45 PM
xcbullet's Avatar
xcbullet
It starts now but maybe should keep socket in bag to be able to do that if needed on the road. Hopefully it was a one time deal. Just checked again & pump primes. Going to check the hook up may be bend all the pins a touch. Tried finding that code with no luck
Old May 30, 2015 | 12:51 PM
xcbullet's Avatar
xcbullet
Stiggy it looks like 3 wires to it a b & c. Which do u ground.
Old May 30, 2015 | 12:55 PM
Stiggy's Avatar
Stiggy
Its been a few years but I think it was the green/grey wire.
Old May 30, 2015 | 12:56 PM
xcbullet's Avatar
xcbullet
OK one was green & dirt
Old May 30, 2015 | 12:59 PM
Stiggy's Avatar
Stiggy
Yep, that's the one.
Captain Itch
Oct 13, 2017 06:37 PM
skizman
Jun 25, 2017 03:58 PM
aarcronnie
Electrical/Lighting/Alarm
Feb 12, 2017 03:04 PM
gusotto
General Topics/Tech Tips
Nov 7, 2016 04:25 PM
clap
Jul 16, 2016 10:37 PM
