Check engine
Old Jul 16, 2016 | 02:40 PM
clap's Avatar
clap
Default Check engine
How do I bring up a code on a 07 Lowrider. Bike was idleing in drive and just shut off and now check engine light is on.
Old Jul 16, 2016 | 03:18 PM
Coolaid's Avatar
Coolaid
Hold in the trip odometer reset and turn on the key if I remember right
Old Jul 16, 2016 | 08:50 PM
nevil's Avatar
nevil
http://www.fixmyhog.com/video/troubl...-codes-008010/
Old Jul 16, 2016 | 10:37 PM
clap's Avatar
clap
Thanks guys I got my codes pulled up and it seems to be a fuel problem Whenever I turn switches on and if you hear the fuel pump it will start and run for a minute or so then shut off. And sometimes when you turn switches on and you dont hear the fuel pump it will not start. I wondering if the fuel pump is goin bad . I checked the fuel pump fuse and the wire connector under the gauges. The only other connector is inside the tank as far as I know. Is there a connector I dont know about?
xcbullet
May 30, 2015 12:59 PM
joebotics
Nov 29, 2012 05:33 PM
09hdrdr
11
Aug 7, 2012 08:20 PM
jaycruiser
May 18, 2009 08:08 AM
kuleli
Sep 1, 2008 04:08 AM
