Radio Install Wires
Old May 31, 2015 | 08:51 PM
Cull22420's Avatar
Cull22420
Default Radio Install Wires
I installed an aftermarket radio to my 2007 Electra Police Bike conversion.
I need to install a 12v constant and a ignition lead.
I have a 12v wire, but I'm trying to find a good Ignition lead wire to tap off to. Any suggestions...yes i'm being lazy and not getting my multimeter out. It's easier to ask people on here. Thanks in advance.
Old Jul 24, 2015 | 12:29 PM
Greazy Jungle's Avatar
Greazy Jungle
2nd Gear
I have a 2002 Police bike and had some issues as well.
I used the Biketronics kit for police bikes and they have you use the Cigarette Lighter as the switched/ignition power (pre-wired with a little connector do-hickey that lets you piggy back into the cigarette lighter post), and generally one of the left-over police wires for the constant 12V.
I found the wiring harness that is used for all the police functions; it was cut and tied back inside the fairing (good) and cut and tied back at the battery/fuse box area (bad).
Traded a couple of emails with the very helpful Biketronics peeps and with some direction I isolated one of the wires in the 'useless' harness, installed an inline fuse and connected it to the B+ - extracted the other end of said wire (there's 6 or 8 in the harness) and used it as the constant.
Old Jul 24, 2015 | 01:01 PM
todd-67's Avatar
todd-67
On the newer bikes there should be a second set of conectors on the headlight harness that is not being used. That is also ignition driven. You can grab the hot from there. That is how i wired in my gps.
magilla_gorilla
Electrical/Lighting/Alarm
Mar 6, 2015 12:39 PM
oldwildwally
Apr 12, 2013 03:08 PM
robfaulkner
Dec 21, 2009 09:44 AM
Badbagger
Apr 28, 2008 02:00 PM
jbhawley
Mar 1, 2007 04:20 PM
