Rear Turn Signal Mounting Question
Old Jun 1, 2015 | 02:32 PM
Lunchboxx's Avatar
Lunchboxx
Default Rear Turn Signal Mounting Question
Arlen Ness Xenolen Black Archfiend Red LED Turn Signals
http://www.jpcycles.com/product/306-951
How do I mount these to use as rear turn Signals? Is there a mount available? Or do I have to make my own? currently I have the stock tribar set up. its a 2001 Road Glide
Thanks
Jeff
Old Jun 1, 2015 | 02:53 PM
mkguitar's Avatar
mkguitar
these are most easily used to replace turn signals on models where the signals mount through the fender strut...which is most H-D models except touring.
you could make something up
the page has this warning:
Note: This item is a universal/custom fit component, and does not have any direct standard/OEM model application. Some items may require modification and an advanced level of mechanical skill and/or knowledge for installation.
....but why bother with turn signals which are not DOT compliant.
there is no point if the drivers can see them- and just an excuse for cops to pull you over.
on my older bikes without turn signals I use arm signals....but many younger drivers don;t know what they mean
you may find the stock lollipops ugly- and they are...but they are instant "that's a harley", you can also use a brake/turn/run kit and swap in red lenses.
or there are other custom light solutions which will be an easy bolt on/ plug in
mike
Old Jun 1, 2015 | 03:13 PM
Lunchboxx's Avatar
Lunchboxx
Thanks Mike I know your right I just thought those were cool looking and would look good. I did see Kuryakyn has a shorter tribar set up That I think I like better.
panhead_pete
Jun 18, 2018 06:52 PM
Sledge
Nov 10, 2012 01:34 PM
cappy
EVO
Feb 1, 2011 07:14 PM
Kadorja
Sep 8, 2010 07:50 AM
redheadfred
Oct 10, 2006 12:12 AM
