Cruise Control Question
Old Jun 12, 2015 | 08:43 AM
swomack's Avatar
swomack
Default Cruise Control Question
When I set my cruise control as soon as I let go of the grip it disengages. Anybody know what may be going on? It worked fine the last time I used it...
Old Jun 12, 2015 | 10:23 AM
tOSUSteve's Avatar
tOSUSteve
Check if fuse is ok. Check if your brake light is on all the time.
Old Jun 17, 2015 | 07:08 AM
Weavr99FLHT's Avatar
Weavr99FLHT
What year/model? Cable or TBW? Carb or injected? Info would help
Old Jun 17, 2015 | 08:28 AM
rufasim's Avatar
rufasim
What gear are you in. You have to be in at least third
Old Jun 17, 2015 | 08:46 AM
Pix's Avatar
Pix
Does the cruise indicator go from red to green....so many questions so little time.
Old Jun 17, 2015 | 09:32 AM
SafetyMan's Avatar
SafetyMan
Assuming you are talking about your 2006 FLHTCUI, check your front brake lever, sometimes they get a little weak, allowing them to keep the brake light on.
An easy check is to push it forward, away from the grip, and hold it with the cruise set, if the cruise stays on, that could be your problem.
Was on my '07, I got in the habit of "bumping" it forward with my fingers.
mlbmd
May 20, 2017 08:32 PM
Rickv8z
Sep 11, 2012 03:11 PM
05 RGLIDE
Mar 5, 2012 04:16 PM
07Custom1200
Apr 18, 2011 09:49 AM
NarleyDavidson
Jan 28, 2011 11:48 AM
