ABS Light Issue
Old Jul 13, 2015 | 01:40 PM
DaddyKnuck's Avatar
DaddyKnuck
Default ABS Light Issue
My 2012 Ultra started doing something odd this morning. When rolled backward with the engine running, the ABS light comes on and stays on after a short while. When backed up engine and key off, started and run going forward only, no light. The flashing light that goes away after 3 mph works in both instances. Brakes work fine in both conditions. When the light is on is there ABS? Any ideas on a fix will be appreciated.
Old Jul 13, 2015 | 01:46 PM
Hogpro's Avatar
Hogpro
Former Sponsor
It should flash until you hit 3 MPH either way. Sounds like it works properly.
Old Jul 13, 2015 | 03:15 PM
DaddyKnuck's Avatar
DaddyKnuck
I didn't explain the problem properly. The initial flashing works as it should. Flash briefly, then go out. However, if I start the bike before rolling backwards, the fault light comes on again after a short period. Roll out of a parking spot before turning the key on (just go forward), light flashes, but no fault light afterwards.
tinsnips
May 24, 2019 09:31 AM
sixgun95
Oct 22, 2014 01:28 PM
MikeB
Aug 21, 2012 08:08 PM
wulffman
Feb 22, 2010 07:18 PM
Big Twi$t
Apr 21, 2009 11:22 AM
