Speedometer off 20kph
Old Jul 19, 2015 | 05:39 AM
floyd2's Avatar
floyd2
Default Speedometer off 20kph
Had this bike for a couple of years and speedometer is showing 120kph when I'm doing 100kph according to GPS. Would this be the speed sensor needing to be cleaned/replaced?
2009 FLHTCU
Old Jul 19, 2015 | 04:44 PM
LA VIC's Avatar
LA VIC
2009 FLHTCU
I'm not familiar with a sensor causing an error. That's a huge error. If you have a good Harley dealer I'd discuss it with them. Notice I said discuss. I wouldn't let them start throwing parts at it unless they can actually correct the problem and you only pay for the bad part. The shot gun method will be costly. I've had 3 touring Twin Cams and the worst was about 3% fast at 70 on my GPS.
Old Jul 19, 2015 | 08:55 PM
wscott's Avatar
wscott
2009 FLHTCU
Thats not uncommon, I also have an 09 flhtcu that when the speedo's at 60mph the bikes actually doing 56mph per gps and local police portable radar trailer.
Once you know your speedo's amount of error its easy to deal with & not worth going after to correct IMHO unless someone & or dealer knows an easy procedure to recalibrate it since you already know how far its off.
If not that you could also install a SPEEDO-HEALER thats an aftermarket programable electronic unit you hook inline with the speedo to correct any error it may have.
Scott
Old Jul 19, 2015 | 10:11 PM
LA VIC's Avatar
LA VIC
Scott
I'd have to respectfully disagree. A 12 MPH error at 60 MPH is ridiculous.
Old Jul 19, 2015 | 11:08 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
The obvious question here is do you have the same size tires as those that came on this bike new?
My bike has 20,550+ miles on it and my speedometer reads about 1-2MPH more than my GPS reads at 70MPH.
Old Jul 19, 2015 | 11:21 PM
sn95bullitt's Avatar
sn95bullitt
Buy one of these. Plug and play and you can adjust it yourself.
http://pages.ebay.com/motors/link/?n...599127&alt=web
Old Jul 19, 2015 | 11:28 PM
Hausguy's Avatar
Hausguy
A Powervision will allow you to correct this.
Old Jul 20, 2015 | 03:47 AM
floyd2's Avatar
floyd2
I realize there is aftermarket ways of correcting it, but wonder why it's off so much in the first place and what part needs replacing. I'll talk to the dealership and see if it's a simple flash to fix. I usually try to avoid the dealership.
From Dakota digital website on their speed corrector
2007 and later Harley models require hardwiring into stock harness, speed correction can be made up to Harley's factory margin of error, typically 3-5% from the actual speed reading. If correction is made beyond this, it may result in the loss of the 6th gear indicator light and cruise control.
Old Jul 28, 2015 | 03:34 PM
RetDetSergeant's Avatar
RetDetSergeant
5th Gear
My bike was originally off by 2 mph faster than actual speed. I had a Thunder Max installed and now I am able to fix the problem and now I am dead on.
Old Jul 28, 2015 | 04:43 PM
leeroynakd's Avatar
leeroynakd
has the trans sprocket been changed?
