assistance please
Old May 1, 2007 | 12:41 AM
Rollon's Avatar
Rollon
Default RE: assistance please
Ye old torque wrench pays for itself; especially considering the TIME you have to take to fix an over torque!
Old May 1, 2007 | 12:52 AM
Bryan TTM's Avatar
Bryan TTM
you can go from fine to coarse but not coarse to fine....listen to choochoo, he's right on the money...the rest will shut that smart mouth the first time they strip one
Old May 1, 2007 | 01:43 AM
im's Avatar
im
will go to the auto part tuesday and see what they have.
got under the bike with flashlight and noticed that the hole threads in about 1 inch deep easy....the drain plug is only 1/2 inch threaded...that first 1/2 inch in the trans pan is clean now with the strip-out but it does leave the other 1/2 inch threaded hole..whats up with that? space for magnet to catch stuff??
got the long aluminum string (strip out) off the bolt and remnants left in the hole out...looks like i got 99% actually counted the turns of the stuff...i will refill the trans. and flush out when the repair is made (just in case)..
thank you again.
will update with results.
Old May 1, 2007 | 11:16 AM
smknflms's Avatar
smknflms
..they make drain plug repair for oil drain, not sure about tranny..might also try:
http://www.****/forums/showthread.php?t=57524&highlight=stripped+drai n+plug
Later
Old May 1, 2007 | 11:26 PM
im's Avatar
im
thank you to choochoo and Bryan TTM
thank you again, bought the 1/2-20 oversize SELF TAP magnetic plug at napa for about $7 with plastic washer.
installed it put some trans. fluid...drained and refilled..everything is good no leaks on test run..i also bought the piggy back drain plug just in case (double oversize) but did not need..
thanks again for your help...info/ priceless and $7 nice!
Old May 1, 2007 | 11:28 PM
im's Avatar
im
oh by the way it is nice when you go to the autopart and tell them exactly what you need rather than the scratch your head and move your fingers deal..
thank you.
Old May 1, 2007 | 11:34 PM
choochoo's Avatar
choochoo
Glad it worked for you.
Been an Auto / heavy Equipment mechanic for over 30 years.
Seen a lot of these in my time.
Pm me if you need help on something in future
Old May 1, 2007 | 11:36 PM
RanD's Avatar
RanD
I'm glad your repair was successful. That must have really pissed you off. I've done it before; not on the H-D, but on an ATV. I'm glad I bought a service manual before I did my H-D trans., because had I not checked the torque spec, I surely would have done the same thing. Its a fairly light torque spec.
grubsie
EVO
Oct 15, 2020 12:34 PM
Chris Golding
May 26, 2019 10:44 PM
ckamin
May 25, 2019 07:16 PM
spgtti
May 25, 2008 12:41 AM
im
May 1, 2007 12:03 AM
