Question regarding pipe change
Old Aug 7, 2015 | 10:05 AM
jkeeton81's Avatar
jkeeton81
Default Question regarding pipe change
Ive ordered some pipes, headers, A/C and the fuel pak 3 for my 2015 SGS.
I plan to do the install myself, but have never done a full pipe change, just slip-ons. Are there any little things I might be missing that I need to purchase or have to properly get everything going?
If I was informed correctly, with the fuelpak 3 I will not be required to take it for a dyno correct?
Thanks
Jason
Old Aug 7, 2015 | 10:11 AM
todd-67's Avatar
todd-67
All 3 gaskets. If the fuelpack has the right map no need for the dyno.
Old Aug 7, 2015 | 10:30 AM
jkeeton81's Avatar
jkeeton81
Thank you
Old Aug 7, 2015 | 12:04 PM
skratch's Avatar
skratch
do you have a manual? there is a specific order as to how you tighten the header nuts up, you don't just throw them up there and tighten them. plus the torque spec is not very high either.
Old Aug 7, 2015 | 12:09 PM
jkeeton81's Avatar
jkeeton81
Thanks Skratch,
I do have a manual for the bike and assume the pipes will come with one...maybe not though. I plan to watch a few videos to make sure I know what Im doing lol
Old Aug 7, 2015 | 05:15 PM
Uncle Paul's Avatar
Uncle Paul
You usually need to snug up the pipes on their crush gaskets, and then again after a couple hundred miles.
Old Aug 7, 2015 | 08:43 PM
dforeid's Avatar
dforeid
^^ +1, Also, put some anti-sieze on the studs... you will be glad you did later....
Old Aug 7, 2015 | 08:51 PM
Deucedog's Avatar
Deucedog
After you have everything installed, make sure to wipe the pipes down with a soft cloth. If you leave greasy (sweaty) fingerprints may get
'burned in' when the pipes heat up.
Old Aug 7, 2015 | 10:05 PM
OldPhat's Avatar
OldPhat
Fallow the Pipe instructions along with manual on proper torque, have some
anti-seize & blue loctite handy. It will not be that hard to do.
Antman1
Milwaukee Eight (M8)
Jul 27, 2019 10:19 AM
sh4325
2014-2024 Touring Models
Aug 16, 2018 09:13 PM
skully1200
Jul 31, 2016 12:01 PM
jpbonesaw
General Topics/Tech Tips
Nov 18, 2010 04:06 AM
monkish
Aug 19, 2009 08:52 PM
