I am doing my 10,000 maintenance and the check list says i need to lubricate the steering head bearing, i look in my maintenance manual and my lord i need to remove inner ans outer faring
This is how I do my '12 Street Glide. Should be the same on the 14 unless Harley relocated the fitting? Are you sure you're not looking at an adjustment procedure?
The 2014-15 steering head has to be taken apart to service , this is done on the 25k service, 13s and older had grease fittings for servicing every 10k miles.
Wonder why the increase in maintenance mileage for the 14's and 15's.Did the factory come up with a new type grease that lasts longer or decide lubing steering head bearings wasn't needed at a lower mileage.Anyway,I glad my 2013 has a zerk fitting.
Probably because it's a bigger pain in the *** to do LOL.
