Replacing exhaust gaskets
Old Aug 24, 2015 | 10:32 PM
Harley Limited's Avatar
Harley Limited
Originally Posted by Egldr05
I have had a Dragula and now have a Rush Wrath which is pretty much the same pipe. I've used the Cometics on both. I have never had a sealing problem with these.
Rick
https://www.denniskirk.com/cometic/e...prd/263766.sku
Unfortunately, I will not have time to wait on these. I didn't know I was going to run into this problem or I would've been more prepared. Oh well, live and learn.
Old Aug 24, 2015 | 10:46 PM
Retrop's Avatar
Retrop
My method consists of taking a small piece of steel wool to clean out the inside of the exhaust port in order to remove any debris which has stuck in there. I just put my finger on a small piece and swirl it around a time or two.
Then I smear some Vaseline or other grease all over the exhaust port and the new exhaust gasket. I then carefully push the gasket into the port using my fingers. Once it has gone in as far as possible using pressure from my fingers I use a large socket and very gently tap it in the rest of the way using a small ball peen hammer. The secret, if there is one, is using the lubricant on the gasket.
Old Aug 25, 2015 | 04:52 AM
Egldr05's Avatar
Egldr05
With that pipe I would try the SE gaskets as an alternative.
Rick
Old Aug 25, 2015 | 05:39 AM
RANGER73's Avatar
RANGER73
I used one of these
Jims Exhaust Gasket Installer
Old Aug 25, 2015 | 07:31 AM
HogAir's Avatar
HogAir
Anyone have any secrets that makes it easier to get the exhaust gaskets in place? Was going to put my new Drago 2's on so I purchased new exhaust gaskets from HD as Drago recommends. Pulled the old ones out with no problem but cannot get the new ones to go in without damage. Rear one went in fine but the center of it ballooned out all the way around it for some reason. Don't know why it done that. Cannot get the front one in at all. Tried pushing it in by hand like the rear one with no luck and tried getting it started then using old pipe and flange to push it in, also with no luck. It just messed it all up. Thought about using some sandpaper on the gaskets to touch them up a bit. What do you all do?
Give this a try...
Sent from my iPad using IB AutoGroup
Old Aug 25, 2015 | 12:44 PM
turckster's Avatar
turckster
Did you use the flat gasket or the cone gasket? I seen that video. Guess I'll have to find a set of those.
I installed the tapered type exhaust gaskets but I would think the tool would work on both types of gaskets. I bought mine from Mac tools but I'll use them at work. If I wanted to save a buck or two I would have got them from Harbour Freight. It did a great job of holding the gasket still while I pushed the gasket in.
Old Aug 25, 2015 | 04:44 PM
Harley Limited
Went to Harbor Freight and bought the bearing race driver set. Put the gaskets in the freezer for a little while. I put the gasket on the driver and pushed them right in. Worked like a charm. Thanks for all the suggestions.
Old Aug 25, 2015 | 04:53 PM
GTK's Avatar
GTK
Originally Posted by OldEnuf2NoBtr
Put them in the freezer. Then I use a 3-4" piece of PVC pipe that has an outside diameter of 1&7/8" to set them into place.
He knows a thing or two.Good advice
Landcruiser
Exhaust System Topics
Aug 18, 2014 11:56 PM
trnewman
May 12, 2013 09:18 PM
RidemyEVO
Mar 9, 2010 10:02 AM
Rowdy25
Sep 23, 2007 11:08 PM
Zimbob
Mar 22, 2007 12:25 PM
