Clutch Cable Routing
Old Sep 1, 2015 | 03:23 PM
sanman4ever's Avatar
sanman4ever
Default Clutch Cable Routing
09 Street Glide
My clutch cable is getting pinched between the frame and triple trees when the bike is on the jiffy stand. The service manual states down the left side of steering head and then between engine guard and front of left frame down tube.
I assume this means behind the engine guard? Also what's the big spring on the cable for down by the transmission cover? Seems to have no use other than rub on the engine mount and harness?
Attached Thumbnails Clutch Cable Routing-clutch-cable-1.jpg   Clutch Cable Routing-clutch-cable-2.jpg
Old Sep 1, 2015 | 04:44 PM
mkguitar's Avatar
mkguitar
the spring can be for a slight constant tension on the cable sleeve- this may keep the O ring better seated
sorry can;t really see routing from your pics
mike
Old Sep 1, 2015 | 04:48 PM
dawg's Avatar
dawg
Hard to tell from the pics you posted but it looks like a non-stock cable that someone installed wrong. It should come out of inner fairing and go down behind the engine guard on the left then cross over in front of the down tubes and underneath the oil filter housing and rear master cylinder and under cam chest and back to clutch release cover.
Old Sep 1, 2015 | 05:19 PM
lp's Avatar
lp
Route the cable behind the engine guard on the left side if possible.
The spring is a guard to keep your engine case from rubbing a hole in your clutch cable.
Old Sep 1, 2015 | 07:39 PM
sanman4ever
Originally Posted by dawg
It looks like a non-stock cable that someone installed wrong.
That would have been me, it's installed in front of the engine guard. I'm going to replace it out. I don't like how it's been pinched. What do you guys recommend for a replacement? Magnum seems popular.
Old Sep 2, 2015 | 04:58 AM
skydude426's Avatar
skydude426
The clutch cable should go over the engine guard on the left side. It looks to me like the cable might be too short to route it properly. It's better to have a cable 2 inches long than 2 inches short. That's been my experience anyway.
Dispatch
May 29, 2018 10:59 PM
IMKMA
2014-2024 Touring Models
Apr 19, 2014 07:07 PM
thequietracer
May 17, 2011 09:51 AM
IDSTC
Apr 14, 2011 09:34 PM
Dan0
Aug 18, 2010 07:55 PM
